That’s a great price for that Tube!!
Can you request the code for Convoy S2+ CREE XPL HI 3000 - 3200K 840Lm Flashlight with U4 7A tint? Thanks.
Make sure to report back once your order gets delivered!
Active codes
31/1/2018
Available for these countries:
HK,US,CA,MY,TW,GB,IE,AU,NZ,IN,SG,ZA,PH,GR,NL,HU,SK,CZ,HR,BG,SI,RS,TH
just got 15PCS USB LED Mini Flashlight for 38 cents AUD, in Australia it costs $1 for a national postage stamp ofr a basic envelope, how i can get 15 of these from overseas for 38 cents i do not understand.
thanks Bilakos
That’s strange, our country uses US-style plugs.
But many times, the discount codes only work for the EU-plugs and not for the US-plugs; ergo, I just order the EU-plug type since it has the discount…
Gearbest didn’t include any US-plug adapters…
Great deals Bilakos… :+1: but you already know that
thanks Bilakos
I got the 18650 power bank case for 63 cents. People must be losing money on these somewhere in the supply chain.
Just ordered two of the powerbanks, 0.98 cents; the 5 pc USB Led’s show “coupon expired”
I also ordered one :+1:
Does anyone have any insight on the quality of the portable powerbank case? I know it’s inexpensive, but I don’t want to ruin my 18650’s
Active codes
31/1/2018
Convoy S2+ 365nm Nichia UV Wat erproof LED Flashlight
$ 12.99
bilakosJ199LiitoKala Lii - 100 Smart Universal Battery Charger
$ 2.99
bilakosJ198LiitoKala Lii - 202 USB Batter y Charger
$ 3.99
bilakosJ200Portable Power Bank Case DIY Box 18650 Batte ry Charger for Digital Devices
$ 0.49
bilakosJ202
Do you have a code for Poland?
hi bilakos, any codes for 14500 batteries? gearbest has soshine brand here
also looking for a code for some protected 18650s like these icr or these ncr
There are no 5000 mAh 18650 cells. That pictured cell is a fake.
This has become such an addiction!!, yesterday I went to buy metro tickets and in the comments section I typed in “bilakosj202 “
I might need help
Gearbest is real. The picture of the 18650 cell is real. The printed label stating 5000 mAh is real. However, the advertised capacity is fake. One of the Answers to the Questions on the gearbest page states the capacity to be 1200 mAh. That is probably closer to the truth.
this is real picture from Gearbest where i buy this battery. Gearbest.com not fake website. if fake they do not sell.
G43…
Its not that its a fake ultrafire, it is real ultrafire…
What everyone here is trying to tell you is that it’s over rated for the mAh spec. As MtnDon said it’s probably only around 1200mAh (or less)
But don’t worry its a common practice for some of the off-brand batteries to have inflated mAh specs.
We just want you to know what you have, some of these low quality batteries could be unsafe. Please be care full not to let the battery voltage drop below 2.5v and don’t overcharge it either.
Do a search on the forum for “fire battery” and start reading…
http://budgetlightforum.com/search?q_as=fire%20battery
it always hurts when “uneducated” people buy things like that…. [image] Link to the shop
I’ll add those to the list:
http://lygte-info.dk/info/batteryDisassemblyUltraFire%20UK.html
http://lygte-info.dk/info/batteryDisassembly9900mAh%20UK.html
4 new deals have been added on top of the previous ones!
Active codes
31/1/2018
The battery pictured is “real” in the sense that if you ordered it, GearBest would ship you an Ultrafire battery that says 5000 mAh on the wrapper. The problem is, Ultrafire lies about the capacity of the cells. They will take the cheapest battery they can find, and slap on a lable claiming 5000 mAh. If you were to test one of these batteries, you would be lucky to get an actual capacity of 2000 mAh. Not only do they lie about the capacity, by using bottom-of-the-barrel, potentially recycled cells, these batteries have completely unpredictable discharge characteristics. If you tried to use them in a flashlight drawing 3-4 amps, they might be permanently damaged, or even fail violently.
The current highest capacity 18650 cells are 3500 mAh. All high quality 18650 cells are made by a handful of companies - Samsung, Sanyo/Panasonic, LG, and Sony. Other brands, such as KeepPower and Orbtronic, take these batteries, add a protection circuit, and put their own lable on it, but they are still a Samsung, Sanyo, etc. cell underneath. Also, some flashlight brands may take these batteries, put their own wrapper on it, and slightly inflate the capacity in the process. So if you see a Klarus 3600 mAh battery, that is actually a 3500 mAh battery made by Samsung or Sanyo, but it is still a high quality cell.
But if you see 18650 cells with an advertised capacity of 4000 mAh or above, they are lying, and highly unlikely to be using a high quality cell underneath.
