UV might been also a good 4. color
What MCU are you using?
That is very impressive Flashy Mike!!! :+1: …
Attiny 841 with 6 PWM channels which can almost freely be assigned to 8 output pins.
Yes, I was also thinking of UV but not with this light since it will also be used by my children. If I use UV in an other multi color light I probably will add some security code into the firmware to avoid unintentional activation.
I decided to ‘Foybezel’ my Q8s. :partying_face:
I used a belt sander with a 40-grit belt, an orbital sander with a 120-grit disc, and a few minutes of hand sanding with 180-grit and 400-grit laid on a flat surface.
I also applied some thin strips of adhesive vinyl between the fins to tell them apart.
Nice job goshdogit. They all look very neat.
Very nice.
Very cool Flashy Mike and goshdogit
no modding for me.
I wanted to do a spring bypas. First investigated the screws. The head srews are ok, but the tail pcb screws, one of them has a bad notch(? ), (there were the screwdriver goes in) so i can’t open this screw. I have no solution, mabey one of you got an option?
Here are ways to remove a stripped screw:
https://www.ifixit.com/Guide/How+to+Remove+a+Stripped+Screw/13213
Thanks, i’m going to need dremel for this
Before you do that I would recommend ordering some replacements of higher quality and less resistance so that way at least you have a working light until those come in. Also, you will have a few hundred more lumens with the replacements since you plan on bypassing anyway.
thanks
Received my first Q8 last week. Overall Build was great. Tail end-Screws for the PCB board were not stripped. the holes were already chamfered. Head end-screws for the driver looked fine. the holes in the driver looked bigger than threaded holes so i didn’t have to oversize them. it was oily on the other side. just gave it a wipe. the annodization on the threads on the tube and head were thin and some spots worn out. it was a little gritty as well. that is the only negative about the entire light. Cleaned and re lubed. nice and smooth now. Love the ramping UI. The only mod i have done is the tail spring bypass. Would love to have TK’s UI with Lightning/candle mode. not interested in buying parts for flashing as i am not a avid modder.
long shot but anyone happen to live in Calgary, Alberta that flashes lights?
May the force be with you .
Could you help me mod my BLF Q8 to Oslon Black Flat leds?
Can the stock driver be modded to run the Oslon Black at highest safe overdrive current?
What would have to be done to the stock driver if it can be modded?
Is their a led board that will work with the correct placement of the leds?
Is their small enough led board that I could use 4 of them correctly located?
Can I just use Artic Alumina to isolate the driver from the host?
Also might have to isolate the reflector from the led board?\
Any help greatly appreciated.
Yes
No
No
No
Probably yes, but see line 7
No
Yes and it will be hard with separate boards
Sorry I cant quote so much from mobile.
You can use this MCPCB, its isolated from the center pad of the black flat: led4power
In the Q8 should fit 4 16mm MCPCBs, so you have to cut the mosleds a bit to fit.
Than it could work with the stock driver.
As I modded my Solarstorm T4 with black flat, I was not aware of the negative center pad and I at the first tries I used it therefore in direct drive (3x Sony VTC5 and 4x Black Flat). They survived.
Q8 reflector is too flat at the bottom. No place for wires.
There is a recess in the bottom center of the reflector.
If I take the stock board out and replace with 4 separate ones (if any are small enough) that will leave space between each of the boards that was previously filled by the stock board. It will be very close but I think if I clock each board with the + and - solder points toward the center where the reflector has the relief it might work. Maybe I can cut small flat pieces of copper to extend the + and - contacts to the center recessed area if necessary? Would be much easier if had single board like stock light. Hope I can find a single board that would work.
