☢ [Bilakos10 Premium Deals] ● Astrolux FT03 SST-40 ● Astrolux A01 UV ● Seeknite X6S ● JCD 8898 Hot Air Station ● SQ-D60
I haven’t seen FR in your country list for quite some time… :frowning:
Here's another set of deals guys!
Everything is available in the OP as well.
Active codes
3/2/2018
Available for these countries:
HK,US,CA,MY,TW,GB,IE,AU,NZ,IN,SG,ZA,PH,GR,NL,HU,SK,CZ,HR,BG,SI,RS,TH
The Boruit RJ - 02 R5 300LM IR Sensing LED Headlamp comes up as $6.99 for me?
For me too.
I am sorry guys :slight_smile:
The correct price is $6.99
Working from my mobile phone is quite difficult!
https://www.gearbest.com/chargers/pp_226450.html
Code for this charger possible?
Edit: I see UK plug is selected when I go to the link, I need US plug
Convoy S2+ CREE XPL HI code is expried, I wil try tommorow again.
I believe that I will be having a code for this charger by tomorrow.
The code seems to be working fine for the V2 1A tint.
Have you used a similar code in the past?
Yes I did buy 3 of these with your codes in the past :cry:
https://m.gearbest.com/batteries/pp_681016.html?wid=21
Code for this too?
Convoy S2+ 365nm Nichia UV Waterproof LED Flashlight - bilakosJ199 code has expired.
Could you please renew the code for this?
Thank you
Would the Boruit RJ-02 be good for general work such as working on cars and getting up in the attic? I’ve got a Black Diamond headlamp but it’s only 200 lumens and the batteries do not last very long since it only use 3 AAA’s.
Wellp, it’s only about 300 lemons, so won’t appear that much brighter, but the 18650 will last forever by comparison, and will have essentially constant output ’til it runs down, vs 3×AAA which is a constant steady decline in brightness from the first second you turn it on.
But it’ll take any 20mm TIR lens, so you can swap in a wider-angle lens (eg, 60° or wider) if the come-with one is a little too throwy, or swap in a really narrow-angle one (eg, 5° or 8°) if you want more “reach”.
Most cases, I keep it as close to minimum as I can set it, and that’s usable light (for me). Only rarely do I need more than that, and you can get instant-maximum by going to wave on/off and turning it on.
Runtime is about 3hrs+ (about 1A in a 3400mAH cell would be 3.4hrs), and that’s at full-tilt. Anything less, and runtime will be way longer.
Then that’s why it might be showing up as expired to you.
The simplest solution would be to create another account at GB just for placing this specific order.
Active codes
4/2/2018
ROFIS TR20 18650 LED Flashlight
$ 39.99
bilakosF17
Still pretty bright:
Hmm, that’s only about 140-150 lemons…
I was about to post a similar comment but I said nah, no one has noticed it so I will let it pass…!
I posted something in the Image King thread, and am almost positive nobody noticed. :smiling_imp:
