Would the Boruit RJ-02 be good for general work such as working on cars and getting up in the attic? I’ve got a Black Diamond headlamp but it’s only 200 lumens and the batteries do not last very long since it only use 3 AAA’s.
Wellp, it’s only about 300 lemons, so won’t appear that much brighter, but the 18650 will last forever by comparison, and will have essentially constant output ’til it runs down, vs 3×AAA which is a constant steady decline in brightness from the first second you turn it on.
But it’ll take any 20mm TIR lens, so you can swap in a wider-angle lens (eg, 60° or wider) if the come-with one is a little too throwy, or swap in a really narrow-angle one (eg, 5° or 8°) if you want more “reach”.
Most cases, I keep it as close to minimum as I can set it, and that’s usable light (for me). Only rarely do I need more than that, and you can get instant-maximum by going to wave on/off and turning it on.
Runtime is about 3hrs+ (about 1A in a 3400mAH cell would be 3.4hrs), and that’s at full-tilt. Anything less, and runtime will be way longer.
Then that’s why it might be showing up as expired to you.
The simplest solution would be to create another account at GB just for placing this specific order.
