Active codes
4/2/2018
Available for these countries:
HK,US,CA,MY,TW,GB,IE,AU,NZ,IN,SG,ZA,PH,GR,NL,HU,SK,CZ,HR,BG,SI,RS,TH
Active codes
4/2/2018
Still pretty bright:
Hmm, that’s only about 140-150 lemons…
Lightbringer:Wellp, it’s only about 300 lemons, so won’t appear that much brighter,
I was about to post a similar comment but I said nah, no one has noticed it so I will let it pass…!
I posted something in the Image King thread, and am almost positive nobody noticed. :smiling_imp:
bilakos10:I was about to post a similar comment but I said nah, no one has noticed it so I will let it pass…!
Are you talking about the h-exceptional t(h)ree?
Lightbringer: bilakos10:I was about to post a similar comment but I said nah, no one has noticed it so I will let it pass…!
Nah, the guys eating lunch on the I-beam.
Does it have to do with the guy 4th in from the right?
Nah. Sad Keanu is eating his lunch, too.
Convoy C8 arrived this week, thanks!
Can you get this one reactivated?
100 mm Digital Vernier Caliper Micrometer Gauge Electronic
https://www.gearbest.com/hand-tools/pp_189799.html?wid=21&lkid=12676948
$ 2.99
bilakosJ14
You are welcome
Do you have any mods in mind?
https://www.gearbest.com/hand-tools/pp_189799.html?wid=21&lkid=12676948$ 2.99
bilakosJ14
Even if I don’t get to reactivate it, rest assured that I will request a new code
Any chance for another code for the Convoy S2+ 365nm Nichia UV? Thanks!
I have already requested one for today. We have to wait to see if I will be given one.
bilakos10
If I remember correctly, you will get notebook on 9.2.18?
Is this correct?
Then it will be easier for you to post new codes
can you get a deal on this again Bilakos?
beam0:Convoy C8 arrived this week, thanks!
You are welcome
Well, I got it for a host to put in XPL HI NW and a FET driver, however I ended up putting the battery tube on my Sofirn C8F to add knurling to it, I’ll probably also use the tail cap (once I do spring bypass) to add a tail switch to the Sofirn. Already have a Convoy SS bezel on it so now it’s a ConSof Probably will still mod it later for another version of ConSof C8
bilakosJ14
Thanks.
I picked up the B158B a little while ago, thanks. I want to build another pill for it, but thought I would see if you can get a code for the empty one?
https://www.gearbest.com/led-flashlights/pp_266236.html
I just purchased the B158 coupon code is for the Red LED.
Do I need to order 1 of each of these pills to have Green and White?
https://m.gearbest.com/led-accessories/pp_572165.html?wid=21
https://m.gearbest.com/led-flashlights/pp_266236.html?wid=21
Are they different?
I also purchased the b158 that comes with a red led.
Looking for a coupon for 2 pills.
Are these pills different from each other?
