PKCell ICR10440 350mAh (Blue)
Official specifications:
Brand: PKCELL
Model Number:10440 3.7V Lithium Li-ion Rechargeable Battery
Type: Li-Ion
Nominal Voltage: 3.7V
Nominal Capacity: 350mah
Model: icr10440 350
Dimension: 10.2mm*44.02mm
Nominal capacity: 350mAh(NOT HIGH DRAIN)
Nominal voltage: 3.7V
Shape: cylinder
Color: blue
Top: Flat top
Usage: e-cigarette
Weight: 15g
AAA sized LiIon cells, how good is this brand?
Up to 0.5A the cell works fine, at 1A it has lost some capacity (Sorry, only curve for one cell) and it cannot do anything at 2A
Conclusion
The performance of this cell is not very impressive, but that is the same for most 10440 cell. The capacity is always around 300mAh and some can deliver more current than other, this one here is not a high current cell!
Notes and links
Comparison to other LiIon batteries
