Thanks. Looks nice, but the total output is stated as 40W, so at 5V that would translate to 8A of current. If you take away 3A for the QC3 port, then that leaves you 5A for the remaining 4 ports. 5A ÷ 4 = 1.25A per port, on average.
Also, when I select the US plug, it says it’s “discontinued.”
At this point, I’m still leaning toward the one I linked to in my original post as it seems to come the closest to my requirements since I haven’t been able to find anything comparable that costs less.
What is it you’re likely to be charging concurrently? Will they all pull 2 amp charge each? If you are going to plug in more than one phone or a phone and tablet then only one of them will be getting the fast charge of QC3.
If you’re planning small battery powered stuff e.g. - I have various things like Bluetooth headphones , action-cams etc…with small capacity batteries. They never take more than 0.5 amp when charging and you’ll be fine.
I am using Aukey wall chargers last years, we have 4 of these chargers at home with single or double ports. Build quality vs price is really great, the internals are good too, not like one of those cheap PCB build chargers.
There are several models that would fit your needs, they ship fast too, at least to the Netherlands.
Here the models which would intrest you (and no I don’t work for Aukey )
