Convoy C8 arrived this week, thanks!
Can you get this one reactivated?
100 mm Digital Vernier Caliper Micrometer Gauge Electronic
https://www.gearbest.com/hand-tools/pp_189799.html?wid=21&lkid=12676948
$ 2.99
bilakosJ14
You are welcome
Do you have any mods in mind?
Even if I don’t get to reactivate it, rest assured that I will request a new code
Any chance for another code for the Convoy S2+ 365nm Nichia UV? Thanks!
I have already requested one for today. We have to wait to see if I will be given one.
bilakos10
If I remember correctly, you will get notebook on 9.2.18?
Is this correct?
Then it will be easier for you to post new codes
can you get a deal on this again Bilakos?
Well, I got it for a host to put in XPL HI NW and a FET driver, however I ended up putting the battery tube on my Sofirn C8F to add knurling to it, I’ll probably also use the tail cap (once I do spring bypass) to add a tail switch to the Sofirn. Already have a Convoy SS bezel on it so now it’s a ConSof Probably will still mod it later for another version of ConSof C8
https://www.gearbest.com/hand-tools/pp_189799.html?wid=21&lkid=12676948$ 2.99
bilakosJ14
Thanks.
I picked up the B158B a little while ago, thanks. I want to build another pill for it, but thought I would see if you can get a code for the empty one?
https://www.gearbest.com/led-flashlights/pp_266236.html
I just purchased the B158 coupon code is for the Red LED.
Do I need to order 1 of each of these pills to have Green and White?
https://m.gearbest.com/led-accessories/pp_572165.html?wid=21
https://m.gearbest.com/led-flashlights/pp_266236.html?wid=21
Are they different?
I also purchased the b158 that comes with a red led.
Looking for a coupon for 2 pills.
Are these pills different from each other?
Active codes
5/2/2018
Available for these countries:
HK,US,CA,MY,TW,GB,IE,AU,NZ,IN,SG,ZA,PH,GR,NL,HU,SK,CZ,HR,BG,SI,RS,TH
Man, shipping is $4.62 for 3 of those Ultrafire 18350s… Wouldnt be bad if I could order the 6-8 that I need…
Thanks anyways for the code
bilakos10
Is this correct?Then it will be easier for you to post new codes
You are correct.
At Friday I am returning home for 10 days and afterwards I am hoping to serve in a camp that’s closer to my house.
I will definitely try to get you something!
Ordered the Convoy S3 and AAA Tool with Nichia. Thank you bilakos10!
Maybe you can request again soshine cases for 18650
And EA X6
Thank you
Please try for this one too…
https://www.gearbest.com/led-flashlights/pp_5499.html
Roger that
Code request https://www.gearbest.com/batteries/pp_663891.html?wid=21
for good price ,please.
Any info?
Any info?
