Test/review of Vapcell INR18650 2400mAh (Purple)
Official specifications:
  • Model: INR18650
  • Size: 18.3*64.8mm
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 2400mAh (0.2C discharge)
  • Min capacity: 2300mAh (0.2C discharge)
  • Weight: Max:46g
  • Internal resistance: Max:10mOhm
  • Standard Charge: 1000mA,CCCV 100mA cut-off
  • Charging Time: 3.5hours(standard charge)
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 30000mA
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~70°C
  • Storage: Temperature –5°C~35°C, Humidity <75%RH
  • Standard environmental condition: Temperature: 23±5°C
  • Humidity: 45-75%RH
This is a high current cell with not that much capacity.
The two cells tracks nicely and they can deliver 30A.
I had to skip the temperature curves, I forgot to replace the battery (It last about a year).
Conclusion
The battery is a bit low in capacity, but it can deliver a lot of current.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
Thanks for the test HKJ!
Beats VTC5A. :slight_smile:
Interesting discharge curve shape, remembers me to that of Vapcell INR18650 2000mAh (Black) and those of Samsung INR21700-30T 3000mAh (Gray) and its Vapcell INR21700 3100mAh (Purple) rewrap.
One of the 30A discharge curves is trimmed off. Maybe the cell overheated?
Cheers :-)
It lost contact, maybe due to overheating.
At the same time, it’s quite normal is the rewrap of the cell Samsung INR18650-24S (2400mAh typical and 30 amps continuous real), the best cell 18650 in 30A continuous of all time nobody did better than this cell until then in this type of cell 18650 (30A continuous).
