beam0
(beam0)
February 5, 2018, 2:47pm
1783
Well, I got it for a host to put in XPL HI NW and a FET driver, however I ended up putting the battery tube on my Sofirn C8F to add knurling to it, I’ll probably also use the tail cap (once I do spring bypass) to add a tail switch to the Sofirn. Already have a Convoy SS bezel on it so now it’s a ConSof Probably will still mod it later for another version of ConSof C8
Thanks.
mrmatt
(mrmatt)
February 5, 2018, 3:42pm
1784
I picked up the B158B a little while ago, thanks. I want to build another pill for it, but thought I would see if you can get a code for the empty one?
https://www.gearbest.com/led-flashlights/pp_266236.html
chooma
(chooma)
February 5, 2018, 3:48pm
1785
I also purchased the b158 that comes with a red led.
Looking for a coupon for 2 pills.
Are these pills different from each other?
bilakos10
(bilakos10)
February 5, 2018, 6:27pm
1786
Active codes
5/2/2018
Available for these countries:
HK,US,CA,MY,TW,GB,IE,AU,NZ,IN,SG,ZA,PH,GR,NL,HU,SK,CZ,HR,BG,SI,RS,TH
Pulsar
(Pulsar)
February 5, 2018, 9:19pm
1787
Man, shipping is $4.62 for 3 of those Ultrafire 18350s… Wouldnt be bad if I could order the 6-8 that I need…
Thanks anyways for the code
bilakos10
(bilakos10)
February 6, 2018, 3:28am
1788
gregor:
bilakos10
If I remember correctly, you will get notebook on 9.2.18?
Is this correct?
Then it will be easier for you to post new codes
You are correct.
At Friday I am returning home for 10 days and afterwards I am hoping to serve in a camp that’s closer to my house.
I will definitely try to get you something!
beam0
(beam0)
February 6, 2018, 6:07am
1789
bigm
(bigm)
February 6, 2018, 6:41am
1790
Ordered the Convoy S3 and AAA Tool with Nichia. Thank you bilakos10!
Satan
(Satan@103TFS)
February 6, 2018, 8:27am
1791
gregor
(gregor)
February 6, 2018, 8:54am
1792
Maybe you can request again soshine cases for 18650
And EA X6
Thank you
bilakos10
(bilakos10)
February 6, 2018, 8:08pm
1796
Active codes
6/2/2018
Satan
(Satan@103TFS)
February 6, 2018, 7:29pm
1797
Got Digital Vernier Caliper, thanks.
bansuri
(bansuri)
February 6, 2018, 10:24pm
1798
Endoscope code expired, I’ll start checking your sales page on my lunch hour. Some of these deals are too good to pass up!
Lgn
(Lgn)
February 6, 2018, 11:37pm
1799
Pete7874
(Pete7874)
February 6, 2018, 11:50pm
1800
The code for the wire stripper does not work.
pennzy
(pennzy)
February 7, 2018, 2:29am
1801
Hows the quality on that ? I was eyeing it too , but thought it could not be accurate at that price ?
DoNkEyConN
(DoNkEyConN)
February 7, 2018, 4:17am
1802
Nice, got the multimeter thanks Bilakos!
