what is an alternative way to keep a 17mm driver in place? i have a cheap 18650 zoomable host and it keeps popping out. i have tried soldering it to the pill but no luck. it used to fit tight but not anymore.
If the pill is brass, you could try to solder it with lots of flux and a very hot solder iron, I have a 80W monster for that kind of work.
If the pill is aluminium, at two positions around the driver I solder a thin copper wire around the edge from ground ring to ground ring, if possible I try to start the wire inside a via. After soldering (I try to get the solder all around the edge) I file the edge to shape so that the driver is still just too large for the cavity in the pill, and the component-side-ground-ring filed back to almost flat. Then I solder all the ledwires and last the driver is pressed in the pill between a vice. The driver is then held in place by friction, and it has good electrical contact with ground.
If you don’t need an electrical connection between pill and driver (e. g. if the tube is pressing directly onto the driver when screwed in) you could also glue the driver to the pill with a small amount of Arctic Alumina or similar. Two tiny drops of glue at opposite positions is often sufficient.
The pill is aluminum and I couldn’t even get the solder to stick even with lots of flux. Even feels like a lower quality aluminum. I may try the wire filler as you suggested.
Electrical connection is required but glue might be my only option.
I have an 20700 protected cell from an Acebeam L30. It doesn’t fit in any of my chargers including the MC3000. Which charger can handle a cell this long?
Here is a question that I can’t find an answer to.
Immediately after a rechargeable Li-ion cell is manufactured, what is its voltage?
Is it zero?
Is it perhaps around 3.7v? If it is then charging it to 4.2V would be in a sense over volting it.
How could it be zero when first manufactured? If it is then they would have to have been charged to about 3.7 when shipped. If they are, then why is it that first initial 0V state not damaging to the cell?
I personally think they are manufactured at 3.7V and shipped. (no charging after manufacture)
Also, I have witnessed 10 year old NOS ( new old stock) cells resting those 10 years at 3.7V charging up and performing almost as good as new. Another question would be if a brand new cell was charged to 4.2V, then discharged to 3.7V and put aside for 10 years. Would it still charge up and perform as new , just as a NOS cell does?
Can lithium ion batteries be stored together safely as long as only one positive and negative end are touching? ie: two 18350 batteries in a single 18650 case.
They will if people give them a reason like they have with laser pointers. It is important to follow common sense and etiquette when using our high power lights. All it will take is a few idiots blinding traffic, messing with police and rescue, or children losing their vision from staring into extreme light sources to get the ball rolling on legislation.
I just checked the dutch regulation for bicycle lighting and was quite surprised that no output limit was set. I do think that it will be added at some point.
Thanks for all the non-stupid answers guys. I have another non-stupid question. Can I “bulk out” a hollow pill with a slurry of copper wire bristles and solder blobs, heated with a butane torch? I dunno if I am explaining it well. My plan is to cut some strands of wire into little ~2mm bristles, cut ~500mm of solder into rice sized grains and cast the mixture into my hollow pill. Has anyone tried it? This is to increase thermal mass for the Ultrafire C8 mentioned earlier in the thread… Thanks again!
I think you must first ask yourself if filling up a hollow pil is going to give you a measureable performance gain. Using a standard 1.6mm copper DTP board on top of a hollow pill, if the connection to the edge is well done, will give you pretty good performance already, perhaps over 4A you start noticing a gain of filling up the pill.
some where i saw a blf host diy. I thought it was banggood but can’t seem to find it now it my also have been a sofrin host does anyone know what i’m referring too. thanks
What’s the trick to soldering emitter leads to the emitter board?
I did my first three driver swaps and soldered the leads to the original emitter boards (to aluminium, one copper) without a problem, but now that I’m trying to put a new emitter in my L2 I just can’t melt the solder on the pads.
It is about three things, more of each is better:
*power (but 30W with a quality tip is enough for most emitter board joints)
*contact surface (the pointy end of a small tip is not going to do it, a bit further down the tip where it widens is much better, or use a flat-end tip)
*a clean tip loaded with some fresh solder for a good thermal bridge (oxide layers are excellent thermal insulators)
