ferongr, I was not particularly referring to Agro's issue. I just wanted to point out that rail to cell contact resistances are in the same order of magnitude to that of the cell's internal resistance and, at the same time, they're not constant and predictable. To me this means that in order to get some meaningful data we should at least gather a set of measurements to average for each cell and make sure the cell's well seated for each measurement. Just in my opinion, of course.
The Zanflare C4 does a lot better than expected. Even with my 20A+ cells (LG HB6) with very low internal resistance I’m getting stable and consistent readings. While the reading will obviously be offset due to the rail and contact resistance, if those two remain constant then you get usable and consistent results.
Note that the multiple tests on all slots remain consistent, and increasing resistance also increases the reading consistently. This is a lot better than other analyzing chargers, a very usable result to see the condition of a cell and also a lot better compared to many other chargers.
While you may have received a very good sample or are extremely consistent with cell placement, I think it’s a bit much to expect that level of precision given the price point. Even a 100mah difference in capacity is only around 3% to 5% variation for a 3000+ mAh cell which I think is pretty darn good and consistent with other analyzers in the same price range.
If the capacity measurement changed significantly between reinsertions, the loss on the contacts would be so great that would lead to localized heating. It would also lead to incorrect charging voltage, since the voltage drop would affect the CV phase. The issue with reinserstion in most 2 contact analyzers is with internal resistance measurements.
FWIW the $8 Opus BT-C100 I have is similarly consistent in current measurements (not in IR though). Since I also mostly charge pairs of married cells of 18650s from my electronic cigarettes, if inconsistent contact affected capacity measurements it would show. Since both cells are within 15mAh though, it appears you are incorrect.
For 100mah over a period of hours to perform testing, localized heating at the contacts would not be very significant. As for your measurements always being within 10’s of mAh, good for you. However if we all expected this level of precision and returned all units not meeting this criteria, there would be few analyzer chargers in the $10-$25 range like we see today.
I also have a c100, 2x c3100, 2x li 500, Zansflare c4 and a few others I can’t remember right now. Yes occasionally I can get readings that are quite close, but I’m not expecting 0.2% precision. Don’t get me wrong, I don’t mind if it’s better and certainly don’t want it to be 10% off, but I understand consumer level products are designed to certain price points and set my expectations accordingly.
I charge a pair of batteries every day. If there was that much of a difference between capacity merasurements every time it would be obvious. I’m sorry but with two analyzing chargers and a variety of 18650s (Samsung 25Rs, Samsung 30Qs, LG HG2s) I have not encountered such great variations.
OK, it seems I found the reason for varying measurements.
Temperature swings. When I’m not home heating doesn’t work and temperature goes down by a couple of degrees. I didn’t expect this would be a problem as the cells being measured would be very warm after I return despite quite low ambient temps.
But I took the charger to my fiancee, she measured the 18650B 3 times within 30 mAh. Above 3500 mAh. So I can disregard all the measurements I did so far, but it doesn’t mean there’s a problem with the charger.
The resistance variability is not temperature dependent though…
I got independent confirmation: my C4 measures at least 10% too high compared to Lii-500. That’s after taking into account different termination voltages.
Does anyone know if I can still ask Gearbest for refund / replace long after I actually received the charger?
Also, I can’t help but wonder how many faulty C4s are there in the wild….was it a problematic batch or a single charger?
I have tested my C4 with different brand new cells so far (protected Imalent 18650, protected Acebeam 18650, unprotected Samsung 30Qs, 35Es). Everytime I get significantly higher values on slot #2 than on the other three slots. I also have unrealistic higher capacity values. (Note: The green one left is a Sony VTC5A with only 2.600mAh nominal capacity)
I would be interested if the charger is just measuring wrong or if it really pushes more capacity into the cells which I guess is not possible. But I’d like to be sure. However, I’m going to contact Gearbest to find out what they think about it. To my mind, the analyzation feature of the C4 is crap if I always get wrong values. Even if Gearbest accepted an RMA I’d probably receive just another inaccurate charger in return.
Sorry for double-posting but I thought it might be interesting to know, what Gearbest replied in terms of those high deviations/wrong numbers when doing a NOR test with the Zanflare C4.
I wrote an honest review about the Zanflare C4 on Gearbest’s website. After that, their customer service team contacted me in order to solve the issues I have with my device. I explained in detail about the high deviations concerning the capacity measurement incl. the fact that charging slot #2 always indicates much more than the other slots.
So…eventually, this is what Gearbest calls “problem solution”. Thank you very much! :person_facepalming:
Dear Thomas,
Thank you for your patiencer.
This charger comes with a volume detection function. Voltage accuracy deviation 2; Current accuracy deviation 5; Time accuracy deviation 1. The capacity is tested by charging voltage, current, and time calculations. Due to the fact that it is not a special compartment, the current market can only achieve a 10 accuracy deviation.
The use of interference Including factors: such as the ambient temperature, humidity, battery type, if the battery installed contacts are good or not and so on. For example, if use different brands of the sub-capacity tester to test, there will be some deviations.
So, it’s reasonable to always have 6-10% more capacity indicated than actually is in the battery? And it’s reasonable that the same slot always indicates another 75-125mAh of more capacity compared to the other ones? I know I’m right in the beginning of my learning curve but I feel it hard to believe that this kind of accuracy is useful for measuring cell capacities nor can this charger be used to find adequate pairs of cells to use them in serial connection (e.g. 4s in the new Haikelite MT07S).
Do you still think the Zanflare C4 is a “good” charger?
If you can get a IMAXb6 hobby charger. Unless you have equipment like hkj there’s always going to be some error. But 300 and 400 more mah on 30q just isn’t acceptable it’s like all your parts in that zanflare are at the worst of their tolerances all combined. With a cheap 30 to 50 dollar charger it will be off by up to 10% between my opus and my IMAX there’s never more then 100mah difference Max. Usually closer. The voltage meter on my opus is low by. .07 so it discharges to 2.73 and charges to 4.13 and I’m fine with this. I’d rather charge my batteries to 4.13 helps with cycle life and only a tiny amount of capacity missing.
Don’t expect much help from gearbest. Their customer service is either great or it’s horrible. More of the latter. The rep on here can help usually. But they’ve told you it’s within spec. I’d use my skyrc charger instead it should give you more accurate discharge values.
