These are all on-axis measurements for both bare leds and with a reflector, right?
What I find interesting is that with the reflector, the LEDs up to 4K keep their CCT while for the 5K and 6.5K LEDs the spot is ~500K cooler than the spill, which means that the tint shift in cooler LEDs is different from that of the warmer ones.
EDIT: what kind of sensor do you use? I have an x-bright i1, that came as part of my display calibration bundle, do you think is it the right tool for your kind of measurements?
It’s an x-rite i1pro. You can measure tint (cct and duv, xy coordinates) with the i1 display (pro) colorimeter, but not the CRI, which requires spectral data from a spectrometer. I recommend using the Argyll tools, especially spotread.exe.
For manual reflow we strongly suggest Pb63Sn37 solder paste. Poorer wetting of leadfree solder paste requires precise dispensing and LEDs placement.
The ultra thin solder mask/solder resist is somewhat fragile, especially in hot temperature during reflow process. Avoid any hard and sharp objects on it.
Solder mask is rated to survive multiple reflows up to 300°C only for a brief moment (< 30 seconds). Prolonged high temperature exposure above 240°C will make it less white while still functional
Soldering LED wire can be difficult because the board is very thermally conductive.
Fixes: Use more powerful solder iron with as big as possible tip, pre-heat the base (or the case/host), use intermediate wire (solder a short slave wire to the pad first).
Note: I successfuly solder all the boards using 30 watt solder iron with board temperature of 150C or...
200 watt solder iron at base temp of 100C. I use cheap Dekko 30 - 200 watt iron with big pointy (blunt) tip. My more expensive 20 - 130 watt Hakko Presto is too weak after I modified it to finer tip.
Just to add to the soldering discussion:
For soldering wires to the MCPCB pads, I use a faulty 60W soldering iron.
It doesn’t stop heating, keeps going hotter and hotter, until it glows dark red (you can see it when you turn the lights off). When you then touch some solder wire, the solder evaporates or something, at least it’s not on the soldering tip.
But holding the tip on the mcpcb, and then adding solder works perfectly, like working on a normal pcb.
