I hope you don’t fall for that. Once you close the dispute, AE might see the issue as resolved. Also, you have no assurance that the seller will honor his word.
Same here, I recently bought a Convoy C8 and also decided to use it’s tube and tail for the same reasons. Also installed the Convoy SS bezel. Now I have a Sofvoy C8F!
Dale, this may have been brought up already, was this statement you posted way earlier in this thread a mistake? (post #81) I only see the C8A with XP-L2.
This was pointed out in another thread and I wanted to clear up any confusion, including my own.
Are you asking about the early version of the C8F?
It had no side switch. Had the aluminum mcpcb. Had xpg3’s. Had a rear tail switch.
They don’t sell that version anymore as they tended to burn up the emitters.
They redesigned it to what you see today. I wish they had changed the name to signify the difference, but they are both called the C8F. Hopefully everyone will forget about the first version.
No I’m not asking about the C8F v1 (I have both v1 & v2)
My question for Dale was for his statement (I put in bold and underline) in his earlier post (post#81) where he stated that the “NEW” C8F comes with XP-L2’s. But as far as I know it didn’t, only regular XPL. Unless I missed something.
I’ll edit out the first part of his quote in my post to avoid this kind of confusion in what I’m asking about.
Just FYI I have the XPL2’s in mine as well (built from a host, not from Sofrin) and the few hundred lumens increase comes with a yellow corona trade off. You aren’t missing anything unless all you care about is MORE POWER!!
I am still a novice when it comes to building lights (so far built a 85cri-nw with Convoy S2+ and a cyan with Convoy M1). I am in the middle of building a triple r9080sw45 219b (thanks clemence!) using this host. I plan to run it at a conservative 2A (I hate turbo modes and my country has warm climate), and the experience so far has been daunting.
I couldn’t use Sofirn’s fet driver as the current would be too high. So I thought I would go with a Nanjg 105C. Could not afford a Pomona soic clip, so hand soldered the attiny and flashed momentary star firmware with some modifications. Now the thick driver retaining ring of this host refuses to fit over (the 2x7135 heatsink tabs on the backside of the driver obstruct the ring). So I must manage this somehow using excess solder. And the spring of the 105C is too short, so I have to buy some new springs :(.
The light engine part is complete though, but that was not easy either. For that I first reflowed the 219s to the dtp board, then attached wires, then screwed on the reflector to the board (this must not be too tight), then applied arctic alumina to the pill, then pushed the reflector-dtp-wires assembly inside (making sure the wires come out properly through the holes to the other side), then tightened the bezel and finally screwed on the center screw (this must be tight for good thermal transfer) going through thr reflector.
Unless there was a glitch in the system? Kept coming up as a new post? I read the same post 4-5 times and refreshed in between by hitting Recent Posts….
The host is a bit tricky to put together but i’m surprised you needed a longer spring. Is the driver sitting in the usual spot since you couldnt use the retaining ring or did you solder it further back? In other lights sometimes people just take some material off the inside of the retaining ring to make room if it’s close.
