Seems like I got a six-pack of counterfeit/fake Samsung ICR18650-30B cells :-/
56 posts / 0 new
Barkuti
Barkuti's picture
Last seen: 12 hours 16 min ago
Mmmkay, got these cells nearly 12 days ago in the mail from AliExpress seller AM battery Store. Did some initial testing on up to 4.2V energy output which came out good but with weird measured voltages against HKJ's discharge graphs, likely due to cells probably being standard ≈2.6Ah 4.2V units.
Pictures and a little clip I shot just after my madness went away:
Unusual top profile in my opinion.
Has anyone seen these 4x wide lobe flat tops on a Samsung cell? Not me.
Bulged wraps. Factory OEM wraps never look this way.
Just before putting 'em together inside a laptop pack I proceeded with a full balanced charge (4.35V) and let them rest for an hour. When I came back, their voltage had nearly collapsed! I connected them again to my charging setup to try to discern what the @#$% was going on, and after a very short while:
Mmm yes, I could improve my pronunciation but guess that's what happens when you can only speak english with yourself LoL! Big Smile
Definitively counterfeit, doesn't it?
Cheers Crying
P.S.: this is not meant to be prejudicial against AM battery Store. I have got good cells from them before this, which is likely caused by some rogue provider. I hope the best for everyone but it's dispute time.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Edited by: Barkuti on 02/09/2018 - 21:37
RobertB
RobertB's picture
Last seen: 2 weeks 6 days ago
This date code shows those cells are already 4 years old
HKJ shows 30B’s to have 3 post positive
http://lygte-info.dk/review/batteries2012/Samsung%20ICR18650-30B%203000m...
moderator007
moderator007's picture
Last seen: 26 min 55 sec ago
Can you see any writing through the wrap on the actual can part of the battery?
Like in the pic here, zoom in and you can read the numbers under the wrap.
https://www.ebay.com/i/302617237052?chn=ps
I’m with ya, they look fake to me. Looks like a pretty good copy though, the wrap is almost perfect just maybe a little sloppier than a factory wrap. Caps appear from your pics to be to big and as RobertB said 3 post cap.
Barkuti
Barkuti's picture
Thanks for pointing out the date code stuff, RobertB.
Got some numbers for you, moderator007: 9L17D1823R9, 9L17D1822R9, 9L17D1821R8… These are underwrap longitudinal orientation codes, and even the last one's characters had oddly shaped, stretched out characters. They don't look like the eBay cells in this regard.
Cheers Party
arztt
Last seen: 2 months 3 days ago
These are fake cells. The positive pole of a Samsung cell always has 3 connections to the body.
Yours have 4.
tatasal
Last seen: 4 hours 22 min ago
Yours have 4.
!https://sc02.alicdn.com/kf/HTB1TE4AQpXXXXc8XVXXq6xXFXXXR/samsung-sdi-186...!
Perhaps the counterfeiters wanted theirs to be more robust? Beer
Barkuti
Barkuti's picture
tatasal wrote:
arztt wrote:
These are fake cells. The positive pole of a Samsung cell always has 3 connections to the body…
The positive pole of a Samsung cell will always be 3 whatever for as long as the brand decides to stick to it. I am pretty sure that if the flat tops of genuine Samsung 30B cells were manufactured with that precise four wide lobe shape its performance would not be noticeably different (and pretty sure the counterfeiters would be pleased if Samsung were to cooperate with them this  way LoL!). What matters here is this single fact: low discharge rate of 30Bs up to 4.2V is 2.5Ah, which is a common figure of lower grade cells. Key difference is their high voltage and ability to cycle up to 4.35V without issue. In fact, thank God these cells have died this way.
My initial testing got me a bit puzzled because the delivered energy was close despite I already knew my measured input voltage didn't make sense. This was due to those cells having slightly more capacity, very much like this, for example:
Just an example, of course (the LGs are 4-lobed cells, by the way).
Cheers Smile
d_t_a
Last seen: 9 hours 4 min ago
Not related to OP’s question, but would like to ask about Samsung date code check in the batterybro website.
I got INR18650-35E and INR18650-30Q.
Checking the date code of the 35Es I got (ordered them Nov 2017, but just got them last month Jan 2018), all the 35E in that order are G25 (Feb 2016) while only 1 is GA5 (Oct 2016).
Looks like these are already in stock for over 2 years.
My 30Qs don’t have those codes below the SDI. Does it mean anything?
Barkuti
Barkuti's picture
d_t_a, the Battery Bro Date Code Lookup Tool is just a sort of reverse engineered hack. And if you scroll down to the bottom of the page, you'll find this: “The Panasonic-Sanyo GA, and the Samsung 30Q are both not currently functioning with this tool.”
Cheers Smile
P.S.: quite nice because I am to receive a 6-pack of Samsung 25R cells and they're for a drill.
moderator007
Got some numbers for you, moderator007: 9L17D1823R9, 9L17D1822R9, 9L17D1821R8… These are underwrap longitudinal orientation codes, and even the last one’s characters had oddly shaped, stretched out characters. They don’t look like the eBay cells in this regard.
Cheers Party
This cell being discussed is a 30Q so I dont know if it applies to a 30B as far as date code.
http://budgetlightforum.com/comment/902171#comment-902171
I searched but I don’t think any one has cracked the code on the can completely but dates should be the same between wrap and can I would think.
Barkuti
Barkuti's picture
Just a little related update:
Seller is either crooked or being mislead by a crooked supplier. Hope for the highest and best resolution in this regard, which of course is the money back in my account and the seller to reconsider its business policy and partnership.
Cheers Party
Lightbringer
Lightbringer's picture
Last seen: 46 min 13 sec ago
Oy… I’m dizzy and seasick after watching the video. Sick
‘Zat a Mickey Mouse thermometer? I want one!
Barkuti
Barkuti's picture
Lightbringer wrote:
'Zat a Mickey Mouse thermometer? I want one!
At least until I can change my DNA and spring forth a thousand Avalokiteśvara style sorry for the discomfort. Big Smile
Mickey Mouse thermometer that's right. My new Bside/Zotek ZT102 was telling me the room temperature without attached probe so I asked him for  confirmation (and they agreed on).
Cheers Smile
Franz
The seller said you sent a false picture…. Facepalm
DENGOH
DENGOH's picture
Last seen: 4 months 4 weeks ago
Have you check your dmm battery level?
Sometimes dmm just gives very strange reading.
cool i'll see you when you get there
Barkuti
Barkuti's picture
Related: Sony VTC5A 6-pack sale from Turmera Powerflagship store
Definitively smells like crooks. Facepalm
Full.
Cheers Party
Jaded
Jaded's picture
Last seen: 3 years 10 months ago
So much for the false slogan “We got your back” customer protection nonsense by AliExpress. From what I can gather, AliExpress tend to favor the sellers more than the buyers.
Agro
Agro's picture
Got 4 disputes so far, all were successful.
Jaded
Jaded's picture
How does it work really, Agro? What’s the best evidence that you used to back up your case?
Agro
Agro's picture
All my cases was packages that wouldn’t arrive. In the ones with tracking that was easy – I could show the item was never sent.
In untracked it was even easier – I said the order was not here, I confirmed that I checked with my local post office and that was it – no evidence needed, I got my money back.
Barkuti
Barkuti's picture
This is as far as things have gone for now. Unfortunately for me, the cells right now are inside a nearby recycling bin as I disposed them Facepalm quite recently (I have poked inside with a flashlight through its insertion hole, and found a green “Samsung” wrap leaning out).
I am going to make the utmost to get them back so I can put them in my recently acquired Lii-500. Since the cells are damaged, even a NOR test will only last minutes.
This is a legitimate defense of our rights and in any case, I swear to God they'll know
Cheers
Barkuti
Barkuti's picture
By the way:
Related link: https://www.alibaba.com/product-detail/Buy-FST-2600mAh-26EB-1000-Times_60672810048.html
These button tops look very Chang Jiang FST to me, don't you think? Flat Stare
Cheers
Barkuti
Barkuti's picture
Another by the way, they're now going to hear from cousin Sam:
Cheers
g_sintornillos
g_sintornillos's picture
Last seen: 7 months 1 day ago
Sorry for my bad English (gogole transtorla)
Barkuti
Barkuti's picture
Vete a  saber, gracias por el apunte g_sintornillos (curioso apodo).
For non-spanish speakers:
Who  knows, thanks for the insight g_sintornillos (curious  nickname).
Related manufacturer links:
https://product.gongchang.com/c771/CNC1690651243.html
Jiangsu Zhihang New Energy Co., Ltd.
Just noticed these Zhihang New Energy cells are only 3x lobed.
By the way, recovered all the cells from the nearby recycling bin just a while ago. Did it with this Wink “tool”:
Be ready to pay dear crooks.
Cheers Party
sb56637
sb56637's picture
Last seen: 2 min 58 sec ago
Creo que en realidad a todos los que frecuentamos este sitio nos faltan un par de tornillos...
raccoon city
raccoon city's picture
Last seen: 12 hours 48 min ago
Location: Palm Desert CA ~ West Coast is the best coast
one_more_post
One more post!
sb56637
sb56637's picture
raccoon city wrote:
one_more_post
One more post!
Whoooeee! Party Thanks, I didn’t even notice. Here’s hoping for 7000.
MRsDNF
MRsDNF's picture
Last seen: 2 days 17 hours ago
I love to hate sb’s milestone giveaways. Facepalm
Speed4goal
Last seen: 2 years 2 months ago
I hope it works out and you get your money back. In the original dispute message with aliexpress. Why didn’t you mention that Samsung cells only use 3 prong tops and that these cells are 4 prong and not made by Samsung. Proving they are counterfit. Idk but it may have helped with the check box on counterfeit goods
And even asking that the seller provide proof that Samsung has given them written permission to sell their goods as aliexpress claims. Because if they had Samsung’s grace to sell loose cells. Then the seller would be getting the cells directly from Samsung and not a middle man. As far as I understand and I maybe wrong. Samsung only sells directly to oems. Just some food for thought
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
Barkuti
Barkuti's picture
Speed4goal, the mere fact that the videoclip I made and linked in the OP is refuted by the AliExpress Case Management team means they're either technically illiterate or biased (without excluding the possibility of being both as I believe it could be, true OR logic versus XOR).
As you can see above I sent a related inquiry to Samsung SDI Security Reporting Center, hope I get an answer so I can upload an email screenshot for them to see.
There are certain things in all of this stuff who simply smell straight bad, like the dispute “message history” being deemed invalid for final resolution. This leaves me with 500 characters of comments.
If I were the old me, I'd already sent all of them DIAF.
I'll make sure to play my cards right, suggestions welcome. 4x prong/lobe thing noted, I asked Samsung SDI about it.
Cheers Party
