I Agree with this one although I am highly concerned that if I decide to build one with S2+ in a month or so Lumileds will maybe release HiCRI Vs and then I will regret?
Carclo stated efficiency of 92% for 10507 with MZs.
Yes, that’s actually just what I did after posting :person_facepalming:
They haven’t tested the Luxeon V yet, though. I know it wont be good but actual numbers and beamshots are still a nice thing.
MZ would be brighter of course at any current, and Vf is crazy low,CC regulation would be maintained ~100% of time even at high mode, I'm just not sure how well it would work with small optics, total die size is bigger than tir entrance holes. Since I got 20mm mosDTP boards,I will build M1 with 5000K 80CRI MZ, just to see how they look in flashlight, XHP50.2 was total disappointment because of terrible tint/coronas.
I wonder what’s the relation between Luxeon MZ, Luxeon M and Luxeon MX…
Is M the same as MZ, but with a dome and larger package?
If yes, dedoming should bring the same performance at low currents and better at high - due to larger thermal pads.
MX is an upgraded variant of M. Eyeballing photos it seems to have about the same die sizes. And doesn’t look flip chip. And emission profile looks the same too. Is there a chance of it being better than MZ?
They all have same MZ core (4x4.2mm,4x Z ES chips), M and MX have full dome and white ceramic 7070 frame, footprint is the same for all leds, MX is basically updated flux bins Luxeon M, I don't see other differences.
Lower max soldering temperature, higher max current, higher Vf. Though slight differences may not actually mean a different product…
I had troubles reading the pad specs…thermal pad is the same. Good for compatibility, bad for performance.
Anyway, if that’s the case, dedomed MX should reach about XHP35 HI luminosity. Maybe even higher.
Thermal pad is big enough anyway, performance gain with bigger pad would be hard to see (I'm not saying that 7070 pad would be bad,but Philips did this for compatibility reasons).
Currently probability of finding higher flux QW (3V bin) of MX is second to none, for small quantities at least. There is higher chance of getting 3V M but just in 3000K and maybe 4000. I made few quotes on taobao asking for availability of LXR7-QW57/QW65 versions of M and they are out of stock everywhere.
I will keep searching for them but meanwhile if someone find reasonable source I would greatly appreciate sharing it with me and others
I updated the luminance values for all LEDs shown in test chart except Luxeon MZ (due to irregular light distribution)!
To ensure more realistic values for 'real-life' conditions (flashlight use / secondary optics) I established a new testing method to determine the luminance with a SMO reflector. All upcoming and already existing tests will use this method!
Updating of my other tests will be done in the next hours / days.
Quite good output thermal stability, with ≈91.92% (728/792 lumens) relative light flux at 145°C (+60°C) and ≈103.283% (818/792 lumens) at 25° (−60°C). :THUMBS-UP:
You surely have something you generate the charts from….spreadsheet(s)? csv? Something else?
For me just dumping it directly would work. It doesn’t need to be nice and clean and easy to work with.
