Uh, no, if I dropped a $2000 11lb light I would have much bigger problems than a tiny drop of liquid metal.
But just from looking at it, the gap between the mcpcb and heatsink is so small that the liquid metal can’t run out.
The only runout happens if you apply too much initially, it can seep out when you tighten the MCPCB down, but as I said you can just wipe that off.
I meant that this tiny drop can damage your $400 reflector.
And also that I simply don’t like general statements like “Using conductonaut between the MCPCB and heatsink is fine, it does not seep out the sides.” as they may not be always applicable.
The liquid metal simply rolls off of a surface unless it is purposefully rubbed in using the swab it comes with.
Kinda like mercury where it just forms small balls that don’t stick.
The only concern using liquid metal is that it is conductive and can short stuff which is why you need to be very careful using it in a PC.
Here, worst case scenario is that a $5 LED driver gets fried.
But no, I can say that there is certainly not going to be any liquid metal coming out from between the MCPCB and cooling block, there is literally a few microns of space and it is impossible for a fluid with such high surface tension to seep out.
This is like being concerned that regular thermal paste will leak out from between a CPU and heatsink due to them not being perfectly flat together. It simply never happens. The only stuff that can possibly come out is during the initial application.
The block is faced on a lathe and the MCPCB is perfectly flat as far as I can tell.
Any polishing I try to do would make things worse.
The liquid metal already gives a large improvement over thermal paste, and that only results in slightly higher current handling.
The only thing which would possibly be of any further improvement is directly lapping both surfaces together, but that would take tens or hundreds of hours for basically 0 improvement (in temperatures).
Yes, exactly. Get liquid metal on any aluminium part and that part will be gone soon. The aluminium will simply fall into pieces
Also Copper + Copper might be a more eternal joint than you would hope, although there is no danger of the copper being corroded away by the liquid metal. If the copper is gold plated like on most boards, this won’t be a problem though.
Yes I have always known that liquid metal reacts with aluminum.
The MCPCB and block are both copper.
As I said before, there is no risk of any liquid metal coming out anyway, there is a fraction of a gram compressed between the two pieces of metal and not enough space for it to exit.
And again, as I said before, even if there is a drop, it forms a ball just like mercury that rolls off of a surface, it does not stick.
It would not cause any damage to the aluminum on the reflector unless it was rubbed onto the surface such that it broke the surface tension and made contact. This would also require a lot more liquid metal than is even applied in the light.
It’s honestly not as scary as people make it out to be.
You even get a ton of applications with the 1g syringe, like more than 10.
I have updated the table because more practical tests have shown that the Synios LEDs are not quite as good as we thought. The luminance of the CFT-90 is also not certain yet. Vinhnguyen54 got 1.58Mcd in a BLF GT and 900kcd in a TN-42 at sub-maximal current. I don’t know of any other values.
He said he got just 20 amps in GT. Frankly, it beats me why so low.
Maybe he posted it as a conservative number that any modded light will reach with much used batteries, but anyway he has a lot of headroom.
Maybe there are too many losses in the main springs.
It’s also a DD light. It’s difficult to base anything off of those kinds of measurements. Measuring high currents obviously needs to be done correctly, otherwise the measurement will reduce the actual current.
I have updated the values in the table to reflect koef3’s newest findings.
I didn’t anticipate having to change them so often… :D.
EDIT:
Since the luminance values of some LEDs are lower than anticipated, we need to also question those of the Luminus CFT-90.
vinhnguyen54 measured 3800otf Lumens and 900kcd with this TN42vn90.The reflector openings have 89mm and 28mm diameter (so 5605mm^2). Lets say that the lens transmission rate is 98% and the reflectivity of the reflector is 85. Lets also say that the reflector collects 75 of the emitted light.
I thus get 4390 led lumens and 193cd/mm^2. sma measured around 185cd/mm^2 at 4400 lumens, so it can be concluded that the values match.
I would be also interested in OSRAM OSTAR Projection Compact KW CSLNM1.TG. In many ways similar to Black HWQP, but newer.
djozz, when I search for Luxeon CX I see some COB…
You’re right, these seem to be even better than the black flat, assuming they can be overdriven just as much.
LUW HWQP: White 3.05 W 325 lm 108 cd 1000 mW 334 mW/sr 120°
KW CSLNM1.TG: White 3.00 W 325 lm 108 cd 1000 mW 334 mW/sr 120° KW CELNM1.TG: White 3.00 W 374 lm 124 cd 1150 mW 384 mW/sr 120°
All three have 1.03mm square die, but the CELNM1 is both brighter and more efficient than the other two.
Also, no notch at all for these new LEDs
There is also this larger version, closer to the Q8WP koef3 tested recently that got almost as high cd/mm^2 as the black flat.
LE UW Q8WP: White 4.20 W 533 lm 153 cd 1650 mW 473 mW/sr 130°
(die size 1.91mm^2)
KW CSLPM1.TG: White 4.20 W 515 lm 171 cd 1590 mW 529 mW/sr 120°
(die size: 1.99mm^2)
The main difference is that the KW has no side emission like the Q8WP did so possibly more of that light is going forward and could potentially give higher cd/mm^2 despite larger area and lower stock output.
Yeah, but CELNM1.TG has a tiny thermal pad. And it doesn’t make up for this with smaller thermal resistance inside the package - actually it’s a bit worse here too. So likely it won’t be possible to overdrive it so much.
This also has a much smaller thermal pad than the older LED.
Due to better efficiency I find it interesting, but I don’t expect it to beat Q8WP.
It’s interesting that now we’re discovering several years old emitters that are great for our application.
And sad how the later generations are often just inferior for what we do.
And what’s worse - we’re not a big enough market to even keep an old product alive, let have one developed for us.
Oh you’re right, I wonder why the CELNM1 has a higher stock output then, if it’s basically the same die.
The CELNM does have higher thermalresistance due to the smaller pad, but what’s cool is that the CSLNM actually has less thermal resistance than the black flat.
For the CSLPM1 even though it has a smaller thermal pad it is still the same size as the CSLNM1 and has the same thermal resistance as the Q8WP, so it might not be that difficult to cool well.
So in summary:
LUW HWQP: White 3.05 W 325 lm 108 cd 1000 mW 334 mW/sr 120° = reference
KW CSLNM1.TG: White 3.00 W 325 lm 108 cd 1000 mW 334 mW/sr 120° = same contact pad size, lower thermal resistance
KW CELNM1.TG: White 3.00 W 374 lm 124 cd 1150 mW 384 mW/sr 120° = small contact pad, higher thermal resistance, for some reason better performance at stock? will not work on any normal MCPCB
LE UW Q8WP: White 4.20 W 533 lm 153 cd 1650 mW 473 mW/sr 130° = large contact pad, lower thermal resistance than black flat
(die size 1.91mm^2)
KW CSLPM1.TG: White 4.20 W 515 lm 171 cd 1590 mW 529 mW/sr 120° = same contact pad size as black flat, same/slightly lower thermal resistance as Q8WP (much lower than black flat)
