The credit is given to me through the use of my affiliate links, not the use of my codes.
bilakos…you haven’t had any codes valid for Poland in a long while…I read it many times that the requesting codes can’t decide what the list of countries would be. But others are getting codes valid here.
Do you know why is it so? Could you tell us more about the process?
This is important to note for anyone buying through this thread that isn’t aware of that, someone unaware may just search for the item on GB and buy it with your code, but didn’t use your link.
EDIT: I actually almost did that once because I had the item save in my favorites on GB, then realized I didn’t use your link and went back here and re opened the product page from your link!
You might want to consider noting it in your sig. or add it on every post you do… Something like: “Please use my links only for purchasing, thanks!”
To be honest I don’t know why GB doesn’t include PL in my countries list.
On the other hand, I have some good news to announce.
For the next while, except from country specific codes, I will also be given codes that will work for all countries
I think I have done that quite often, opened my Gearbest account under a separate tab and assumed the credit went with the named code.
OOPS!
Yes, you must always use direct links from this page.
bilakos10, maybe you can update OP with this info.
Agro:bilakos…you haven’t had any codes valid for Poland in a long while…I read it many times that the requesting codes can’t decide what the list of countries would be. But others are getting codes valid here.
Do you know why is it so? Could you tell us more about the process?To be honest I don’t know why GB doesn’t include PL in my countries list.
Good news. More codes, more possibility to buy something for lower price
Still waiting for soshine boxes and ea x6 :money_mouth_face:
pennzy:What I don’t understand is why you don’t get credit for them if they are your codes ?
It seems to me that with a little tweaking on their end , the process can be fixed to only allow affiliate links to work with that code .
bilakos10: pennzy:What I don’t understand is why you don’t get credit for them if they are your codes ?
That’s still not a solution, as everyone will be able to generate his own affiliate links and not use mine
Hey Bill, I'm looking at getting a multitool. My only requirements are they be Ganzo, black and have a compelling price. Something like:
Ganzo G104 Folding Pliers with 10pcs Screwdriver Bits - BLACK
https://www.gearbest.com/multitools/pp_259436.html
Screwdriver bits non-essential.
Can you make it a valentine's day special? Lol
Also, I know you have mentioned, no Zanflare codes, but does this include the Zanflare B3? Thanks a bunch! (Can't impulse buy the B3 for now, just interested)
Notice: In order for Gearbest to credit my sales, the products must be purchased through the links provided through this topic.
If you have already got a product in your cart and want to use one of my codes please remove it and add it again using the links that are available below.
Active Deals
13/2/2018
The deals below are available for all countries!
Available for these countries:
HK,US,CA,MY,TW,GB,IE,AU,NZ,IN,SG,ZA,PH,GR,NL,HU,SK,CZ,HR,BG,SI,RS,TH
Hey Bill, I’m looking at getting a multitool. My only requirements are they be Ganzo, black and have a compelling price. Something like:
Can you make it a valentine’s day special? Lol
Also, I know you have mentioned, no Zanflare codes, but does this include the Zanflare B3? Thanks a bunch! (Can’t impulse buy the B3 for now, just interested)
I think I have an active code for a similar multitool.
I will search through my DB once I get back home and I will let you know!
OOPS!
There ya go, exactly what I was sayin’
Yes I suggested that earlier, and to put it in his sig (maybe in bold print)
There ya go, I think that will help!
gregor:Yes, you must always use direct links from this page.
bilakos10, maybe you can update OP with this info.Yes I suggested that earlier, and to put it in his sig (maybe in bold print)
bilakos10:Notice: In order for Gearbest to credit my sales, the products must be purchased through the links provided through this topic.
If you have already got a product in your cart and want to use one of my codes please remove it and add it again using the links that are available below.There ya go, I think that will help!
Hopefully it will indeed help.
Thanks for bringing up the issue
Active Deals
14/2/2018
I think I have an active code for a similar multitool. I will search through my DB once I get back home and I will let you know!
Thanks Bill!
bilakos10:I think I have an active code for a similar multitool. I will search through my DB once I get back home and I will let you know!
Thanks Bill!
Check out this code:
Code expired for COB light!!!
is this some kind of Code or Joke???
