ALL THINGS BUDGET KNIVES
[quote=beam0]
Not currently available anywhere that I can find. (Green color)
Gearbest: “Arrival Notice” 89 Notice submitted!
Fasttech; “Discontinued”
Ebay: No
Aliexpress: No
Dhgate: No
No, that works fine, I was referring to pushing the lock and snapping wrist, there’s some vids about this but its tougher on the ganzo cause the lock spring seems stiffer and you cant get much of a grip on the scales due to its smaller size, also the lock has a U shape and its kinda painful when you try it over and over, similar to the G10 pain on the axis models, but iindex finger is being used and abused. it probably is easier to do on larger handle models. I tried some oil on the pivot but seems worse, maybe I will loosen the screw a touch, for $7 your not gonna go wrong if you can find that deal again
That’s the date of releasing of that model. The number is the month and the triangle is the year.
Steve figured that out here.
I took apart dozens of my folders with ball bearings for cleaning the past years and adding some light lube (not a greasy one) always made them better.
That U shape on the lock is called the Boye dent (it’s for preventing unintentional unlocking).
Ganzo F759M and my old school Spyderco Delica side by side. The Ganzo weights 66 g (2.33 oz) while the Delica with the lanyard 57 g (2.01 oz).
Triangle and its shape is Sanrenmu code for production year.
Guys, some posts ago I think I saw someone post a triangular diamod honning/sharpenening device pretty cheap to improve the factory edges not to re-profile blades where is that link i want one one those things.
It was trangular in red plastic?
Thanks apreciate it
On my knives I feel that grease makes the ball bearings slower, oil is no problem.
But I use my SRM Land 910+, my Malyshev Gnome, and my Vespa Neon without any lubricant at all.
Working like a charm and doesn’t collect so much dust.
Only my TiLock clone and my Real Steel Griffin run on bearings with some grease but they are no flippers even though they could flip great with attachable flipper tabs like on the LionSteel Tre…
https://www.youtube.com/watch?v=zKSf5m27jZM (link is external) 1:35
Mine doesn’t do that and it has a rock solid lock-up without the slightest movement not like the one on the video. Jimi might get a lemon.
The worst case Adahn could make you a replacement G10 scale with a smaller cut out or even a CF one! :wink:
Ps. I made the effort and I could flip mine open too. I’m still not a front flipper fan. :slight_smile:
Sewing machine oil for me. I use that oil for folders.
Good to know sewing machine oil works too. :+1:
Well, order 2 of these little fellas to my address (when they are on sale if you like) and get one back with a cf scale.
I could even include a (simple) pattern and fill it up with gidt epoxy.
Just made some shopping cart coinless keys and included a smiley one one and alien eyes on the other one.
Of course I forgot to take pics before gifting it to my sister and my b-i-law.
The skull didn’t work out so well but I guess I’ll try another one.
wow, yes I see what you mean there. I only have a few frame locks (I’m not really fond of them) but none of mine have a cutout on the other side of the handle like that. That is definitely design flaw IMO. Looks like a high chance of it closing up on you when you grip the handle, pushing the lock bar back off.
On the ones I have gripping it would move the lock bar further in, thus locking even tighter.
And yes he called it a “Front Flipper” !
I think i could manage with the “design flaw” on the 5009 but the knife im looking for is for my 11yr old son so i wouldnt dare give him that.
He is already flicking my 7010 fully with his thumb :smiley:
Lansky Master’s Edge?
https://lansky.com/index.php/products/masters-edge/
Thats not the one im refering to something in smallers V, but apreciate your concern
I take my leave showing my current collection of knives
Imgur
Still mising a Ganzo 7511 that im wating to arrive. I discovered that I fancy more flippers knives ,especially with ball bearings or roller berings like the ruike.
do you put the spine of the blade on the bottom thing or just hold the knife in midair?
you hold knife midair, its something smaller portable and cheaper then this ones
Hi guys does Aliexpress have any BM Infidel Clones?
Thanks
