I just asked them about the A3S last night and got the reply today……
They are sold out at the moment , but will be back on the Amazon site when they become available.
I did not get a time frame , but I am pretty sure it will be after the big Spring Festival in China , which I think is still another 2 weeks or so before it is over.
I know I’m late to this reply. But yes I am using the battery they issued. Seems to flicker more when I turn the flashlight vertically. Definitely sounds like a short battery issue.
Just saw the review on that, looks like a great tactical light!
I kind of hope they don’t change the A3S driver though…
What I’d rather see done is they shorten the battery tube and dump the USB battery idea, the longer tube to accommodate the USB battery creates an issue for using a lot of different cells. I guess it was a “quick and dirty” way to compete with some of the newer zoomies with built-in USB charging. Pretty much any of the high drain IMR cells will need a magnet to the negative side (per Newlumen’s helpful suggestion) whicht seems like a good setup on this for 18650.
Firelight2’s revelation about the Convoy/Jaxman tube lego is what really has me stoked for this light (Thanks again Firelight!) I’ll run an 18500 Jaxman tube as well, I’ve got some Efest purple IMR 18500 high drain cells to use in it. Only drawback is shimming the driver side for contact, because that probably won’t be something that easily goes in and out, so swapping back and forth with 18650 might be a PITA. But I’ll more often be swapping back and forth with a 18350 Convoy tube and Aspire INR 1100. I’ll try using a ring of 14g or 12g solid copper wire (Romex type) for the shim mod, if that works.
Robo, you probably know this but this review isn’t linked in your sig, no biggie but thought I’d remind in case you forgot, I use those links to jump around your reviews.
Also I guess they are the same light body but the first 2 sets of slide-show photos are the A3, not the A3S, no biggie there either, just sayin because when I look at those pics I have to check if I’m in the right review :person_facepalming: :laughing: . Maybe you could just make a note of that somewhere around the pics to avoid confusion.
Something else I want to point out on this to avoid confusion: In the “listed specs” (manufacture provided) it shows “Reflector: TIR lens” however it appears to be an aspheric on this. (and hopefully is) Wowtac really needs to fix that, unless there’s some type of hybrid thing going on with this?.
I bought this a week or so ago. But right now it’s boxed up ready to go back to Amazon. I’m sitting on the fence, but leaning toward returning it. The fact that I also bought a Thorfire TK15 that can pretty much serve the same use would make it easier to let it go.
I like the side switch, the UI, and the light output. And with the 20% off, I got it at a great price. But the zoom is annoying. The seal is so strong between the zoom and the body that when you slide it out, it wants to pull back because of the slight vacuum produced inside. You have to hold it a couple of seconds for it to get fixed in place. The same kind of thing happens when you pull the zoom back. Do zooming lights like this every loosen up?
Mine doesn’t do that at all, did you get the A3S or the A3? Pretty sure I read somewhere of that same problem on the A3, and it’s been corrected with the A3S. This review is of the A3S.
The A3S is more expensive, the A3 is a close out.
A3…….(600lm) $19.99
A3S…(1000lm) $29.99
Can’t compare a non-zoomie to a zoomie, if they serve the same use for you then you probably don’t need a zoomie, around here these are usually bought specifically for the zooming function.
Not all the push-pull “slider” zoomie lights are like that. Although screw type is fine in a larger light, personally I prefer the slider type in a smaller light like this because it’s so much faster and easier (and delightful!) to work the zoom one handed.
It’s the A3S (I unboxed it to be quadruple sure). I would post a picture, but it requires an image URL (?). I followed the link that beam0 posted above to Amazon. At that time there was a 20% coupon, so it cost me $23.99, I think.
Something else interesting is that box shows A3S CW and A3S NW with CW checked. I didn’t know this could come in an NW.
