I used the eraser end of a standard #2 pencil. Good luck on the mod, let us know how it turns out for you.
Hmm… That’s the first thing I though but my pencils are 5/16" and the bulb opening is 3/16.
I hope we are working the same flashlight. Do you have the led or incandescent? They look the same from the pics.
Now that you mentioned it, I had to go back and check. I found my origional reflector (I keep all extra pieces), and sure enough the pencil didn't fit. I think I was remembering what I also thought to try first, not what actually worked. My apologies, it's been awhile. I honestly can't remember now what I used, may have been a chopstick.
Heads up though on re-assembly... Once the drop-in is in place and you snap the lens back in place it's there for good, since there's now way to push it out. I had to destroy my origional lens when I went to swap drop-ins. Couple of choices here... You can purchase a stock replacement lens (what I did), or you can hollow out the center of the stock lens till it's just a thin ring and use it as a retaining ring for a standard P60 lens (what I'm going to do...) I'll let you know how it works.
Good point! Didnt think of getting the lens out after the new drop in is in. I’ll have to make sure everything is good to go before I snap it back in. Where did you get the higher amperage driver from? Have to think if i want to do that before i snap the lens in, or just use a different light later in for experimenting.
Where did you get a replacement lens from, streamlight?
I am waiting for the dropin before I bore out the housing just in ass this one is slightly different. Now I just can’t wait. I’m hooked! Lol
You can get a replacement lens here.
The driver I first used was a 2.8a 8x7135 unit from shiningbeam.com.
As mentioned earlier though, a minor problem with that driver is that the chips mounted on the underside get in the way when screwing down the head.
Any of the above linked drop-ins should work fine though on 2xCR123.
I found this forum by google, it brought me to this post. Thanks Match. I too greatly enjoyed my scorpion. It was my first lithium powered flash light and it is what prompted me to buy a 6p. A few months ago my car got stolen, and in it was my scorpion. So I found a cheap one on ebay. It arrived with dead batteries, a melted lens and a dead bulb. But for $10 plus shipping, oh well. I decided I wanted to upgrade the bulb, preferably to an LED. However that seemed to be a dead end. Since I had upgraded my 6p with a cree dropin I decided to see if I could make my old p60 fit. It looked to be similar in size. So I found this post, and in a matter of minutes using a uni-bit I had my p60 in my scorpion. Now I just have to order another cree drop-in and a new lens! Thanks!
hmmm, there's a M@g 2xAA mod thread saying use a 25/32 bit to open up the head to fit the dropin.
Comparing that to 55/64 recommended here -- how come? Do dropins vary that much? (Wouldn't surprise me if they do).
Before I buy an expensive bit and start thinking about buying a little tabletop drill press ...
Hank,
The difference is that in the mini mag thread I only used the pill, whereas here I used the whole drop-in (pill + reflector). The reflector adds a little bit to the overall diameter.
Pogue_Mahone,
Welcome to the forums. I'm glad you were able to get some use out of this old thread! Good thinking on the uni-bit... they're handy little tools. Did the stepped hole it make cause any issues?
-Match
A uni-bit huh? I have a few of those... Maybe I can do this mod afterall!
I have a selection of unibit sizes and the first one I used, I think it was 7/8" max dia. and it didn't open it up enough, so I stepped up to my 1" and it made a nice chamfered edge around the top which actually gave me a little more room for the drop in. I also used a slightly thicker o-ring between the reflector and the lens, as the original was about the same as the size difference between the p60 reflector and the head. It didn't come out perfect, but I'm happy with it. I am now debating on the LED to put in it.
> Price: $1.20
Any one have links to similar mod for the StingerXT rear clicky standard i guess xenon bulb not led.????
I got a couple of these from my last employer. When they stopped supplying batteries (and a paycheck) I chunked them in a drawer. This might be their resurrection! Well for one of them anyway. There's a good chance I could screw the first one up. But you know what they say, "It's better to have one good working light, than to have two you're too cheap to buy batteries for." So what the heck I might give it a shot!
Thanks.
Steve
Welcome to the monkey house, five.five-six.
FYI for those looking to buy these drill bits, if you buy them both at the same time from the same supplier, shipping is combined. So both the 25/32 & 55/64 bits shipped for under $25! (and I imagine you could stack that further if there were some other sizes you needed). Seller seems to have a mix of quality bits and cheapo. I linked the cheap ones, since that's all many of us need for this hobby.
http://www.amazon.com/gp/product/B0007PZFRG
http://www.amazon.com/gp/product/B0007Q3GFS
Nice, thank you.
Hi all,
I’m planning to do this mod on my Scorpion, right now i’m waiting for my U2 drop in from Manafont
the review said that it becomes hot quickly on high-mode, so is there any review about heat management on this mod?
thanks all,
>>bocah>>
Have a pleasant time here at this friendly forum, bocah!
Hahaha…thanks for the warm welcome, raccoon city!
Match’s Scorpion mod prompted me to finish mine that I started last year and then set it aside to play with other projects.
My mods to the head are the nearly the same as Match’s except that I threaded the head and made my own screw in bezel and used a UCL glass lens. The knurling on the bezel is pretty lame (too late at night), but it works.
It is now hosting an R2 dropin that I had and it is now the best thrower that I have. That may change in the future as it will be an easy swap.
