"Throwiest" LED?
55 posts / 0 new
light.speed
Last seen: 3 years 1 month ago
"Throwiest" LED?
From your experience, which LED gave you the most throw? I'm currently running an XHP70.2, and while it is pretty bright, I don't feel like it's really going that far.
Edited by: light.speed on 02/25/2018 - 17:54
Enderman
Enderman's picture
Last seen: 3 weeks 16 hours ago
Dedomed old version XP-G2 is the highest throw.
light.speed
Should have mentioned, but I don't really liked de-omed LEDs, or more specifically the color of them Thanks anyways though
wstrachan
Last seen: 4 days 21 hours ago
Xp-l HI likely. Some companies are building amazing throwers from the XHP35 because its capable of near 3000 lumens and candlepower numbers in the mid 500,000+ range and more.
The XHP70.2 or orignal 70 arent ever going to make a comparable thrower when put against smaller die emitters like the XPL and xp-g series.
Pretty much physics dictate small die+ large reflector equals high candlepower and throw.
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
Enderman
Enderman's picture
light.speed wrote:
Should have mentioned, but I don’t really liked de-omed LEDs, or more specifically the color of them Thanks anyways though
Then XP-L HI is next best.
light.speed
Thanks. So if I'm correct, the smaller LED with more candlepower will out throw a larger LED with more lumens?
light.speed
Thanks, I'll probably try the HI and the 35, and whatever else is recommended to get a feel for them all.
Enderman
Enderman's picture
light.speed wrote:
Thanks. So if I’m correct, the smaller LED with more candlepower will out throw a larger LED with more lumens?
Depends on what LED.
Just because one is smaller doesn’t mean it will outthrow a bigger one.
But the XP-L HI is the highest stock intensity one that cree has available.
light.speed
Sorry if I'm being annoying, but this is my last question. Between the XPL-HI and the XHP35, with would get farther throw?
Enderman
Enderman's picture
The XPL HI does.
light.speed
Thanks
Enderman
Enderman's picture
Throw me in to darkness wrote:
All XP-L HI LEDs are dedomed, aren’t they?
Or am I missing something here?
They have a flat silicone layer instead of a dome, so there is no need to remove the dome yourself.
MRsDNF
MRsDNF's picture
Last seen: 3 days 32 min ago
Does the XPE2 belong in the thrower category in the right torch?
The_Driver
The_Driver's picture
Last seen: 4 days 17 hours ago
Enderman wrote:
The XPL HI does.
They are very similar though. The luminance difference is so small that it can hardly be seen. The XHP-35 HI has a 50% larger die though, so more lumens and a fatter beam at almost the same luminance. Because of the higher Vf it can also be driven by more compact drivers (lower currents).
light.speed
What is a die? Is it the size of the LED?
thulfiqar
thulfiqar's picture
The die is the the Yellow Square that Emits light , The colour of the Die Depends on the LED UV/IR/White….
there are LEDs with 4 Dies Connected Together like this
light.speed
Thanks
Agro
Agro's picture
Last seen: 3 months 6 days ago
All this discussion misses an important point:
to get the most throw from a LED you need to drive it to the max.
This is not what typically happens with any of the mentioned LEDs.
light.speed
What LED would be good for maximum drive?
Agro
Agro's picture
Any. You just need the right driver for your host. Which may or may not be available.
So if you have a host, tell us what it is. If you don’t – ask us to help you find the one that’s right for you.
light.speed
I'm planning to use the Astrolux X when it comes out but I don't know what driver it uses, so I'll guess 17mm
Agro
Agro's picture
You are unlikely to get some definitive answers until more is known about the light.
But:
Do you intend to keep USB charging? Replacing a driver while keeping charging may not be easy. Also, removing it will free some space for large drivers. Which is likely unneeded, but we (I?) don’t know yet.
You intend to run it off a single cell, a pair of 18350s won’t do, right?
twisted raven
Last seen: 5 hours 41 min ago
XHP-35 HI has the generally best tint I’ve seen from any Cree LED; domed or flat. Flat LEDs have the benefit of minimizing tint shit from hotspot to corona to spill in a reflector as opposed to a domed LED. The tradeoff is that they lose some overall lumen output, however I feel that the improved throw more than makes up for it.
You are probably initially opposed to domless or dedomed LEDs because you’ve seen the early 3rd party dedomed Crees with their very Green tint. the factory flat XPL HI and XHP35 HI don’t have that issue.
XPL HI and XHP35 HI have very similar throwing capabilities, but the XHP35 HI does it while outputting more lumens. SST-40 dedomed or thin domed will actually out-throw an XPL HI, and have more lumen output plus less green in its tint as well.
light.speed
Single 18650, but no USB charging
light.speed
True, but I haven't really found a 17mm driver capable of running an XHP35 HI off of a single cell, so I can only practically use an XP-L HI
EasyB
If you are after the most throw check out the black flat LED. It is a domeless LED with 1mm x 1mm size (XPL HI is 2mm x 2mm). You can run it direct drive and it will have significantly more throw than the XPL HI. But be aware it has an unusual footprint; I think it doesn’t have a neutral thermal pad.
Agro
Agro's picture
Realistically I see 3 options:
1. Wait for a suitable boost driver and use XHP35 HI. It will provide the highest lumens, but will overheat shortly and need to step down. Once it cools down you can get output again. Such driver should become available sooner than X, but it is not yet, so you never know. Expect roughly $30 for LED+driver.
2. Use XP-G2 with FET+linear or pure linear driver. It will produce less lumens. XP-G2 will probably have higher throw than XHP35, but not much. XP-L HI will be similar. Little to no overheating problems, but your output will slowly diminish as the battery discharges. Much cheaper than XHP35.
3. Boost the stock driver, maybe replace the stock LED. We don’t know if it’s a feasible option.
Do note that if you want XP-G2, buy it from
https://intl-outdoor.com/cree-xpg2-s4-2b-bare-led-p-885.html
and buy it NOW as this is the last known-good batch and may run-out any time.
And, BTW, why Cree?
You may be better off with Osram Oslon Black. VERY throwy, but few lumens. Somewhat harder to use than other emitters too. EDIT: I see I was not the first to suggest that. Smile
light.speed
Thanks for the help, I'll probably go with your first option
light.speed
Need more output though, might go with an XHP35 HI even though it isn't as throwy
Enderman
Enderman's picture
All the answers given in the thread are assuming he is going to drive it at higher currents than spec.
The XP-L HI is still the best “factory dedomed” LED from cree, with XHP35 HI being second and giving more lumens.
light.speed
By the way, does anyone know what voltage the XP-L HI run off? I haven't been able to find anything on Mountain Electronics or Fasttech's websites.
