Nice idea!
I have the prototype (from the OP) taken apart and re-working the head design for 2 LED emitters and a center post bolt ( to make it simpler & stronger, plus adding a frosted main lens to eliminate the inner globe to lower costs & make it simpler in design.
I hope to get photos of it soon and post an updated blueprint. - DB
I donāt mind the relatively low output, but I can definitely understand how itād seem underwhelming compared to the BLF Q8. Itās designed for a totally different style of use though, where turbo isnāt very relevantā¦ and the lower brightness should help keep the cost down a bit.
Itāll make the lightning storm mode less impressive, but thatās kind of just icing anyway.
Post #1000!
(at the moment)
[quote=ToyKeeper]
Please leave the Lightning Storm Mode as it is, to cooooooool to change
[quote=Stittville Ed]
The point she is making, is the lightning storm wonāt be nearly as dramatic from the lantern because it doesnāt produce the lumens of the Q8.
Iām interested too, only one of course.
A lantern would be quite useful. Do you think it could also fit 20700/21700 cells?
Would like to know.
Would like to know.
This is a great idea. 4 x 21700 could give 16000 to 18000 mAh. A little plastic sleeve could easily convert it for 18650.
Oh yes, that would be awesome. Downsize compatibility is a must. 21700s to 18650 adapters would be excellent.
Put me down for one please.
Interested - 1
Interested in 1
One for me too.
Also interested in on (1) light.
I like where this is going so far, especially when there is a true WW option.
Camping light = warm light.
At least to me that isā¦
Grtz
Nico
At least to me that isā¦Grtz
Nico
Same here, I never understood folks that spend their evening outside with a cool white neon Coleman lantern. :confounded:
Iām in!
Had a situation where this light would have been the perfect solution
Please add me to the list for 1, this souds too good to pass up.
Interested in one.
Thanks.
I read on another thread that the lantern project is going for about 500 lumens on max. Is this true? I would imagine that this might be about the highest output that I would need much of time, but it sure would be nice to have access to a higher turbo level for those times where more light is needed.
Really nice project!
Please add me for one.
Thanks.
