Aw geez. I have so many listsā¦ Um. Letās see. At least part of it is visible. And at least some of whatās visible is published. To see that part, check āanduril.txtā in the repository, which was initially a todo list but is now mostly doneā¦ Also, try āegrep āTODO|FIXMEā anduril.c
ā to see some other itemsā¦
But I also have a variety of other lists which arenāt public. So many, in fact, that I wrote an aggregator system to merge the entire hierarchy together into a single flattened list with scores and priorities and recurring due dates and even a snooze button. Itās called āTKDOā.
And then another aggregator to merge that together with some other systems and data sources, to boil it all down to a single number plus some randomized convenience hints about what sorts of productive things I could be doing right now. That one is called, um, something I canāt say here without violating profanity rules. Letās call it a āscrewometerā since the number shows, in percent, how āscrewedā I am. It even graphs the status over time.
The graph is a relatively recent addition, so it hasnāt had time to populate much history, and Iām still tweaking the factors and coefficients, but hereās a sample of the past 24 hours:
Lower is better. If itās dropping, that means Iām getting stuff done. If itās rising, that means Iām probably either slacking or asleep or doing something it canāt automatically measure. Currently rising since Iām chatting on BLF.
This may have all scrolled off by the time anyone sees this post (edit: nevermind, I linked to a frozen copy instead of a live version), but at the moment it shows me a graph starting at about 38, which then drops to about 20, then rises again to 34% or so. Then it starts dropping again but hasnāt gone far yet. This suggests that I got stuff done yesterday, tasks piled up while I was asleep, and now Iām starting again. But todayās peak is lower than yesterdayās, which means Iām doing something right.
If things go well, Iām hoping to build a USB nixie-style clock I can use to display the current number and trendā¦ but for now Iāve got it displaying on an old 20x4 LCD, the same one I wrote LCDproc for back in the 90s. I donāt have a serial port any more though, so I kinda hacked together a couple of AVR reflashing cables plus some floating wires to give the display power and data. Still havenāt figured out exactly why itās getting inverted and bitshifted data, but I can work around that (ā1 + (254 - (byte << 1))
ā) until a proper usb-serial adapter shows up.
Is this enough of a peek?
