You mean sst-40 ?
Looking for user who can write Emisar D1 firmware, simple 3-4 modes, temperature controled
I just got the green version of the D1. I can’t believe how beautiful it is. Makes me want to collect all the colors of the Emisars now.
Green is the color I had wanted for an Emisar but unfortunately I’ve been reading complaints the (new textured) green color coating is not durable and wears off easily. (is it even anodize?) So now I’m not sure I want it, that has delayed my decision to buy an Emisar altogether until I look into that first.
^ My green D1 is smooth. Ordered it mid-January.
I think the grainy finish is only on D4.
My D1 is smooth green and finish looks perfect. I didnt know the D4 green had rough texture. I thought only D1s had rough textured surface
That already exists. There are several different D1-compatible firmwares which could meet that criteria.
So for the green color the D1 is smooth finish and the D1S and D4 both are texture finish?
Can someone please confirm if this it correct or not?
You can get the latest status by going to Intl-Outdoor.com and checking whether it says “smooth finish” or “grainy finish” next to each color.
D1 only comes in a smooth finish. If that changes, Intl-Outdoor’s page will change.
So for the green color the D1 is smooth finish and the D1S and D4 both are texture finish? Can someone please confirm if this it correct or not?-
OK thanks, got it now…
Green color (currently):
D1……Smooth surface
D4……Grainy surface
D1S…Not available in green
Sorry Giorgo,
Typo, my D1s has an XP-L2 that has been freed of it’s silicone.
Just received my grey D1s today, and can’t wait for darkness so I can see the beautiful 5D tint in action!
There’s one issue I’ve got though - the switch is a lot stiffer than the ones on my D1 and D4, and requires far more pressure for it to click. Is there any way to (easily) change that?
Weird, first I’ve heard of the switch being any different. Has anyone else noticed that?
It takes about twice as much pressure to press than the switches of the other two Emisar lights. Not a huge problem, but if there’s an easy solution to make the switch more responsive I’d like to try it.
Maybe they changed the switches and we’ll see the stiffer one used across the line?
Maybe it’s meant as a workaround for the problems with accidental activation?
Just guessing…
Maybe it’s meant as a workaround for the problems with accidental activation?Just guessing…
It did actually occur to me that it makes it less likely for the light to turn on in my pocket (which has happened twice with the D1). Maybe I’ll leave it and see how I get on with with a harder press.
