BLF GT official support thread [FAQ updated 11 Jan 2018]
I have Issues with the anodisation on my today arrived GT.
There are scratches on the Pill-section and on the first fin of the reflector on both sides of the Pill.
It seem that the Tool is verry dirty and makes scratches.
I will pass this on once they return from CNY. I would send Neal a message about this to see what can be done.
Thanks for answering. I could wipe it away with a little wet fingers. That means anodisation is ok.
Great, I kinda figured it might be the case, the ano on these lights is super tough from what I have seen.
Tough maybe, but not as tough as the person tightening this one.
I have broken two straps due to using piping to get more leverage :weary:
And it is still not open.
Just so no one thinks it arrived like that, it did not, the second strap to break did it.
Cheers David
Pommie, I had the same thing going on with the two I bought, I started with Harbor Freight strap wrenches but had to buy two sets just so I would have 2 large wrenches and snapped both of those, then bought some other of Amazon and broke them as well.
I’ve seen this wrench mentioned before on one of the GT threads but this is definitely worth mentioning again because with this wrench the GT came apart easily.
It’s on Amazon called the BOA Constrictor, it’s more expensive than the others but it works great, BOA strap wrench
Edit: You might need 2 of them really, but it worked well using the big Harbor Freight strap wrench to hold the light in place and this BOA for for breaking the bezel and heat fin sections apart.
Jeez David, what strap wrench did you use?
Knowing the person I borrowed them from they would be mid priced, not top quality but they were all metal so not cheap either, all I have to do now is ask that person what I owe him to buy two replacements :money_mouth_face:
I will find a way, even if I damage it more :smiling_imp: I got it to mod which I cannot do if I can’t get into it.
Cheers David
Maybe we need to replace the o-ring against the glass with something that has less friction. A silicone o-ring?
Maybe we can coat the O-ring in something slippery that won’t dry up?
Now I have found a dead led-die on my gt. I can see it with my eyes if I look to the LED at the lowest mode.
Is this the first DOA-GT?
Thats hard to check for Lumintop and to notice that fault.
Here you can see the spot at a distance of 1.5m:
I put a lens on the GT to show the LED better:
And here you can see, what the lens is projecting:
That’s very strange. Since the xhp35 is 4 dies wired in series. If one die loses power, they should all turn off.
Do you think maybe a dark piece of dust or debris landed on the die and then got burned up?
Now it may be blocking light output.
Well if one of the four dies is less efficient you geht less light for the same current.
Maybe it was on the edge off the spec when Cree selected the four dies?
Well, it is sure not nice, but dead on arrival?
Versuch mal die LED direkt zu fotografieren, unterbelichtet und mit nem ND-Filter
Very strange indeed, this is also the first I have heard of any major issues with any GT so far. Everything else have been minor things.
Like they said, it is very strange that 1 die would burn out while the rest still work. Can you get a picture of the LED itself? Maybe on moon mode as well.
It is hard to make any good picture with my Nokia 808 PureView Cellphone. But I made some.
I did not have an other camera, only a small old Exilim EX-H10, which makes worse pictures as my cellphone. It has only a small 12MP CCD-Sensor. My Cellphone-Sensor is 1/1,2” big CMOS with 38MP.
Last two pics with the same orientation. You can see the bonding wires.
That is definitely a faulty die in the LED.
I have had the same thing happen to other quad LED’s and the XHP35’s too, but only in Moon light level/mode, anything higher all 4 dies worked…
Try looking at it at higher power through a welding protection glass if it is powering up at higher level.
I see it in higher levels too. I can see the dark edge in the Hotspot, so no need for welding glass.
Bummer Man!
Noticed something else with your centering ring bar too…
All Centering rings in the production lights has this big hole. Only the prototypes had a good fitting centering ring.
