1. sometimes I hear the glass “click” or “pop”, almost like it’s cracking/bursting but then again it’s not. Very weird and not only when the light is on, but also when I do some soft “swinging” with it when off. Very scary!
2. the flat sides on the battery tube are completely off-line/off-center with the switch/button (perhaps this is meant to be or not, but esthetically it doesn’t look good and could be improved for the final product).
3. the black attachment-ring-hole on the head is also completely off-line/off-center with the switch/button (perhaps this is meant to be or not, but esthetically it doesn’t look good and could be improved for the final product).
4. the silver attachment-ring in the tripod-mount-hole is not horizontal in line with the head (perhaps this is meant to be or not, but esthetically it doesn’t look good and could be improved for the final product).
5. one of the small LED on the switch is shining brighter then the other (perhaps this is meant to be or not, but esthetically it doesn’t look good and could be improved for the final product).
All these alignment wishes are difficult to fulfill, it has to do with how threads work. Even if you design and manufacture and tighten it so precisely with the exact amount of force that all alignments are there, over time everything will shift again by wear of the threads and then your OCD starts striking up again. It is not a manufacturing fault, getting these alignments right requires a complete different way of joining two pieces (like bolting them together). Note that many high end flashlights have this exact alignment stuff going on.
Those cracking noises are related to thermal expansion/contraction in the same way you hear heaters or car engines ‘click’. I dont think there is anything to worry about.
No, I’m at work at school, superintending a couple of pupils doing a test atm who are trying to determine the iodine content of betadine (and I’m surfing BLF :innocent: :person_facepalming: ). It must be delivered to one of my neighbours (in the appartment complex where I live we all receive packages for each other, so that is perfectly fine).
Batteries and body arrived today. Packaging damaged here too, as You and one other posted stated before.
It is a good amount of moisture, probably dropped too.
This is a pic from the Carrier.
This end was on the “dropped” end of packet but I would not take a guess if its from manufacturing or if its from dropping.
Does not seem to be significant anyway…
Damn can´t open manual, it´s sludge….Lol.
“The END”. Anodizing has taken some hit. Again impossible to say if it´s from shipping or if it was there.
This was on the “intact” end of packaging.
BUT:
THERE WAS THAT ONE THIN layer of bubble wrap, so that the moisture DID NOT get to batteries.
(To be honest, if I was shipping these, I would probably use a lot more)
Batteries would have maybe survived some moisture but I don´t like the idea of getting them wet & rusty on the contacts.
Just to be clear: All Batteries were dry, unharmed and at decent storage voltage.
