[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
Is the light on the right at a brighter level making the hot spot look larger on camera?
Can you try this picture at a much lower brightness level like moonlight?
Anything above moonlight my camera makes the hotspot appear bigger.
At 9 feet, I get a hotspot diameter of 8” or 20.5 cm roughly.
My corona is also much smaller.
Here’s a tip for removing the bezel. Loosen the upper head from the light engine section first, this takes pressure off the o-ring on the glass and makes the bezel much easier to turn due to less friction.
Why didn’t I think of that sooner. Duh. :wink:
I spent a lot of time doing that and other neat tricks for the first couple of days after I received mine. Another neat trick is to go out on a completely (as possible) dark night and ramp the power as low as possible (not talking about accessing moon just the bottom level of the ramp). Then try to see how far you can detect light. It’s absolutely insane how far this reflector will throw that small amount of light output. This is a very special flashlight and I am so happy that I joined the blf for these and so many other awesome opportunities to see just what is possible. To be able to get advanced and intuitive designed flashlights at a budget price is just icing on the cake imho.
TA I commend you and all the other collaborators on this project. All of you do a great job of proving that “budget” most certainly does not mean CHEAP!
IMHO, This light is the most amazing light i have ever touched. You can call me anything you want, cause I got 2. The only thing that is better is the great light head condom and carry bag that Neal got together. Thank You to the team! There is a round of golf claps to Neal for the fine accessories!
Always Respectfully,
Andrew Whitehill
I doubt it was the use of the word noob.
In my opinion, you come off sounding disrespectful or arrogant like your superior to everyone else. Even your post above sounds kinda rude. I’m not a good judge of tone, but maybe you sound aggressive or that you want to fight?
I don’t know exactly what it is. Maybe based on the words you use and the things you say, your triggering people? IDK.
On a friendly forum like BLF were we try to be helpful and nice, any type of negative attitude stands out.
Maybe someone else can explain it better?
Interesting, have you taken any lux readings side by side with fresh cells in each?
I dont have any lux measuring equiment… but by looking just with the eye you can see a pretty big difference. When looking at both reflectors you can see the ring marks in both but apart from that mine is pretty clear, my dads light is less mirror like. It almost functions like a very ligt OP that makes the hotspot just a little bit wider. I will try to make some more beamshots also on moonlight.
If the reflectors so much different, they can not be good focussed for each reflector.
For my GT, I think its not well focussed, the beam is getting thicker and thicker.
I compared my GT with my Astrolux MF02 and it seems that the GT is not realy brighter than the MF02, but the hotspot is smaller than the MF02 (which is not good focussed too). But you have to remember, that I have a faulty LED: BLF GT official support thread [FAQ updated 11 Jan 2018] - #145 by Wieselflinkpro
The difference in Corona diameter might point towards different LED-position (focus) as a more likely reason instead of just reflector finish.
Seems like focus, not reflector.
and what could be done here, to fix the focus?
s.:
according to tracking, my GT seems to have reached my country yesterday.
Now hopefully I will not have to wait much longer…. :slight_smile:
You could try adding a couple pieces of paper under the black centering thing. See if that makes it better or worse. (this moves the reflector away from the emitter)
If better, add a couple more pieces of paper.
If worse, then you might have to sand down the bottom of the black piece to make it a tiny bit thinner. (this moves the reflector closer to the emitter)
I measured the picture with a ruler :smiley: I got a big 29% difference.
Could you make a measurement of the hotspots? You wrote 3 meters from wall. JasonWW wrote 20,5cm at 9 feet (2,74 meters).
Would paper be a wise choice of material?
I just think about high temperatures and paper….
You may not have a Molotowflashlight afterwards, but maybe the paper could char and disintegrate?
I’m just guessing. Paper should be good enough for testing purposes. Another material might be better for a permanent spacer.
Its less in reall life i guess, the photo makes one spot brighter.
What i also tried is put them on moon light mode and walk towards the wall i will see a square(the led) with mine GT, the other GT there is never really a square it always kinda stays a cirlcle. Maybe other people can try this and tell what they see(or picture)
Look here: Light collimation with an LED flashlight
Can someone providing me Tracking code, pls :frowning:
It’s btw in no way any criticism. Both light throw extremly well. Just slight difference in beam profile, but with so much variables its expected that there are some.
Thanks!
Very good explanation from Enderman…
