[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
19107 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 20 hours 36 min ago
on 3m distance and lowest ramp (on - ramp up a bit - then ramp all the way down) i get a ~14cm spot
 all new deals are also posted here: deals.m4dm4x.com
if you do not find what you are looking for :
ask MARTIN@M4DM4X.COM - i will save you money!
rob799
Last seen: 1 year 3 months ago
Does anyone know where to buy the exact same eye screw connector that is on the GT? I would like to use them on my Q8’s for a lanyard.
Bozlight29
Bozlight29's picture
polarweis wrote:
Both GT's on moonlight about 3 meter distance. Right is mine, left my dads. !IMG_9767
image uploader
I think it’s the reflector. There’s a difference in reflection, my son has almost mirror finish (like it should be), while mine produces a blurry image of everything that reflects.
CrashOne
Last seen: 1 hour 2 min ago
Am I the only one who received just 1 battery carrier with 4 batteries?
For now I’m using some bubble wrap to fill the empty space, so I can at least use the GT with just one carrier.
Essexman
Last seen: 7 hours 47 min ago
https://www.banggood.com/14-Inch-Round-Ring-Digital-Camera-Screw-Bolt-Fo...
I understand they are a std size for cameras and tripods etc
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 8 hours 23 min ago
Yokiamy wrote:
djozz wrote:
I’m going to measure throw of my GT and Nicolaas’ GT somewhere next week, it seems that you and/or your dad are also in or near Amsterdam?, we could make it a 4x GT session then if you are interested.
Too bad i don’t live near Amsterdam, otherwise i’d join Wink
In the (small) Netherlands is all near Amsterdam, isn’t it? Big Smile
Trafic in Netherland is not very fast and it is very strict, thats what I learned in one of my last hollydays.
Texas_Ace
Texas_Ace's picture
Last seen: 1 hour 19 min ago
polarweis wrote:
Both GT’s on moonlight about 3 meter distance. Right is mine, left my dads. !IMG_9767
image uploader
To my eye it looks like the hotspot itself is about the same size, the difference appears to just be the corona, which is what the different reflector finish would do.
This should not have a very large effect on the actual real world throw of the light, as we have seen even the V1 reflectors can light up a water tower at 1.9 miles away. It mostly just causes the hotspot to be smoothed out.
I saw this with the V1 to V2 reflectors but the real world performance difference was only marginal in my case.
I would also venture to say that a focus issue could be at fault.
Maybe the centeirng ring somehow got on top od the screws and cause it to change the focus? Not likely but only thing I can really think of.
JasonWW
JasonWW's picture
Last seen: 10 hours 25 min ago
M4D M4X wrote:
on 3m distance and lowest ramp (on – ramp up a bit – then ramp all the way down) i get a ~14cm spot
Wow, that’s a little further back from me, but a big difference in size. 8” to 5.5” or 20.5cm to 14cm
It almost makes me think the curvature of the reflector is slightly different. I doubt it’s the finish. My guess would be a different reflector height.
ChibiM
ChibiM's picture
Last seen: 7 hours 21 min ago
how about some pictures of the reflectors side by side?
JasonWW
JasonWW's picture
Ah, so Bozlight29 is the dad of Polarweis. Now the above statements make sense. I was confused for a while. Lol
JasonWW
JasonWW's picture
I think I figured it out. I can shrink my hot spot down from 8” to about 6” if I remove the black centering spacer and carefully move the reflector closer to the emitter.
I don’t know if this will have a positive or negative effect when measured further away. I assume it will improve the throw, but I’m not positive.
Polarweis and Bozlight29, do you have different black centering plates? One with big hole and one with small hole? Maybe they are different thicknesses.
Texas_Ace
Texas_Ace's picture
This is a possibility.
JasonWW
JasonWW's picture
In looking carefully at my black spacer, I see that it’s a bit warped. The middle sticks up a little.
This could add a little extra height making the hot spot larger.
Texas_Ace
Texas_Ace's picture
Possible but the pressure from the reflector should flatten it back out I would assume.
JasonWW
JasonWW's picture
My theory is that Lumintop calculated the exact thickness of the black spacer just right, but with a warped bottom, it’s a tiny bit too tall.
I sanded down the bottom of mine until it was flat. I carefully cleaned it with a brush and a metal tool to get rid of any black pieces of plastic on the edges and in the holes.
Now I’ve got a 6” hot spot compared to an 8” (at 9 feet). That’s sounds better to me.
Tonight I’m gonna take identical distance photos that I did in the past and compare the hot spot and corona sizes.
Mr.Scott
Last seen: 1 month 1 week ago
JasonWW wrote:
Kingjohn wrote:
southland wrote:
Seems like focus, not reflector.
and what could be done here, to fix the focus?
You could try adding a couple pieces of paper under the black centering thing. See if that makes it better or worse. (this moves the reflector away from the emitter)
If better, add a couple more pieces of paper.
If worse, then you might have to sand down the bottom of the black piece to make it a tiny bit thinner. (this moves the reflector closer to the emitter)
Yes, but which one is better and which one is worse? I can see they are different at 3 meters, but I can’t say if left or right will better in actual use.
JasonWW
JasonWW's picture
It’s pretty thick. Mine was obviously not flattening out. With the focusing of the reflector such a sensitive thing, a tiny bit of warpage can have a noticable effect.
I probably moved my reflector 1/2 a millimeter closer. That’s a lot! Lol
JasonWW
JasonWW's picture
The smaller the hotspot in a thrower, the better. Your focusing more of the light energy into a tighter, narrower beam pattern.
(Now I wait for Enderman to tell me I’m wrong. Silly )
Actually, I have to assume the factory meant for those black spacers to be flat on the bottom. All I did was take a warped spacer and made it flat again.
I’ll do some long distance measuring with it tonight and see if my light is better or worse.
polarweis
polarweis's picture
Last seen: 7 hours 39 min ago
It gets more complicated, my uncle also got a GT Big Smile
Will make a compersion with his light too.
I will make some pictures of the reflector tomorrow in sunlight. And maybe some beamshots tonight.
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
polarweis
polarweis's picture
The black spacer looks the same. Both small hole. I think the reflector quality does make the corona a little bit brighter on my dads light. I dont think its the focus that is the problem.
Enderman
Enderman's picture
Last seen: 12 hours 31 min ago
Haha Silly
Having a small hotspot on a wall 3m away is not the same as having a small hotpsot at a far distance.
I guess you’ll find out if it helped or not when you take the measurements Smile
Bozlight29
We are almost ready for some beamshots in the Belgium Ardennes. This GT is a great light, whatever the corona or hotspot looks like, the long shots are showing what this light is capable of. The comparison between the GT’s is part of the hobby, not criticism on the GT or it’s designers and producers. Wednesday we can do a comparison of three GT’s, when Megabassie arrives at the scene. Maybe now some folks understand why we are happy the GT’s arrived just in time before our holidays. In Amsterdam is not so much room for large beamshots...
KawiBoy1428
KawiBoy1428's picture
Last seen: 9 hours 39 min ago
Both of my GT’s centering ring bars were trapped by the hold down screws to the point that they had to be pried off. I opened them up till they floated on the hold down screws. As you can see in this picture, the hold down screws are narrower as compared to the centering ring bar clearance holes. This could cause the centering ring detail, not to sit flat due to the interference, how is it supposed to sit Flat when it’s trapped between the screws, this thing should float to allow the reflector to center to the LED, and the mcpcb hold down screws to the centering ring detail should act as a anti rotate.
The centering ring bar measured 2.48mm thick all the way across the board, regardless of the warp on both of my examples, and now measure .012” thinner since machining it. Now in my case, I’m running a clean de-domed XHP35 HD E4-1A, and during the course of tuning the reflector to the clean de-domed LED, I had to move the reflector up .004” to gain the highest LUX measurement at 20M. I made shims out of Precision Brand Plastic Gauge stock.
I made quit a few, of different thickness’s because my other GT is running a XHP70.2, so I played around with Focusing this 70.2 LED too. Now all this has changed a bit again after doing Endermans Tuning Procedure.
So Jason if you need a shim to get your GT back in focus, because .500mm is a huge difference, let me know what size/thickness you need, I have quite a few extra! Wink
KB1428 “Live Life WOT
JasonWW
JasonWW's picture
I’m just guessing .500mm. It might be closer to .250mm. I didn’t bother to measure. I said screw it, let’s just flatten this sucker and see what happens. Lol
polarweis
polarweis's picture
Just made some first long distance beamshots with my dad. This light is sick. Almost no difference with long beamshots.
Theodore41
Last seen: 7 hours 22 min ago
My registered packets came here.The first,passed below Customs radar,but for the second,they ask PayPal receipt so as they set it free for delivery.I will send Neal’s August advance payment of course.
Yokiamy
Yokiamy's picture
Last seen: 34 min 20 sec ago
I just measured my hotspot at exactly 3 m from the lens, i measured just over 13 cm, so 13/2,54=5,11” so i think i’m good
WTB: Jetbeam TCR-1 or Sunwayman V10R Ti
Nev
Last seen: 1 year 6 months ago
Has anyone tried putting a hotspot on clouds? I think the lowest cloud types are around 2000 metres.
CheapThrills
CheapThrills's picture
Hi again!
Just an update: received the head today.
Package badly bruised AND wet.
But it´s ALL GOOD!
No scuffs or marks, only a tiny spec on reflector, glass pretty clean etc.
Boy it´s huge
CheapThrills
I went out despite it´s -28°C now.
I tested it towards a road and a truck was driving a bit away from me in slight angle.
It just casually threw 920 meters. I was like “Ooops, better watch out where I point this…”. Big Smile
That was with fogged glass AND some light snow/hale in the air (glass often gets fogged up in here when it´s cold and you take your lights out from inside the house).
Topic locked
