The smaller the hotspot in a thrower, the better. Your focusing more of the light energy into a tighter, narrower beam pattern.
(Now I wait for Enderman to tell me I’m wrong. )
Actually, I have to assume the factory meant for those black spacers to be flat on the bottom. All I did was take a warped spacer and made it flat again.
I’ll do some long distance measuring with it tonight and see if my light is better or worse.
The black spacer looks the same. Both small hole. I think the reflector quality does make the corona a little bit brighter on my dads light. I dont think its the focus that is the problem.
Haha
Having a small hotspot on a wall 3m away is not the same as having a small hotpsot at a far distance.
I guess you’ll find out if it helped or not when you take the measurements
We are almost ready for some beamshots in the Belgium Ardennes. This GT is a great light, whatever the corona or hotspot looks like, the long shots are showing what this light is capable of. The comparison between the GT’s is part of the hobby, not criticism on the GT or it’s designers and producers. Wednesday we can do a comparison of three GT’s, when Megabassie arrives at the scene. Maybe now some folks understand why we are happy the GT’s arrived just in time before our holidays. In Amsterdam is not so much room for large beamshots...
Both of my GT’s centering ring bars were trapped by the hold down screws to the point that they had to be pried off. I opened them up till they floated on the hold down screws. As you can see in this picture, the hold down screws are narrower as compared to the centering ring bar clearance holes. This could cause the centering ring detail, not to sit flat due to the interference, how is it supposed to sit Flat when it’s trapped between the screws, this thing should float to allow the reflector to center to the LED, and the mcpcb hold down screws to the centering ring detail should act as a anti rotate.
The centering ring bar measured 2.48mm thick all the way across the board, regardless of the warp on both of my examples, and now measure .012” thinner since machining it. Now in my case, I’m running a clean de-domed XHP35 HD E4-1A, and during the course of tuning the reflector to the clean de-domed LED, I had to move the reflector up .004” to gain the highest LUX measurement at 20M. I made shims out of Precision Brand Plastic Gauge stock.
I made quit a few, of different thickness’s because my other GT is running a XHP70.2, so I played around with Focusing this 70.2 LED too. Now all this has changed a bit again after doing Endermans Tuning Procedure.
So Jason if you need a shim to get your GT back in focus, because .500mm is a huge difference, let me know what size/thickness you need, I have quite a few extra!
I’m just guessing .500mm. It might be closer to .250mm. I didn’t bother to measure. I said screw it, let’s just flatten this sucker and see what happens. Lol
My registered packets came here.The first,passed below Customs radar,but for the second,they ask PayPal receipt so as they set it free for delivery.I will send Neal’s August advance payment of course.
I tested it towards a road and a truck was driving a bit away from me in slight angle.
It just casually threw 920 meters. I was like “Ooops, better watch out where I point this…”.
That was with fogged glass AND some light snow/hale in the air (glass often gets fogged up in here when it´s cold and you take your lights out from inside the house).
Just check post one. Right now it’s Chinese New Year. Once China goes back to work Texas_Ace will let us know when he will send out the PM’s. So late Feb or early March.
