To prevent confusion, they are for the Convoys with the metal tailcap, the early ones came with a black waterproofing silicon seal inside the switch that would not let light through. For well more than a year the S2+ already comes with a transparent seal. I have a stash of transparent seals for who still has the old S2+ with black seal and want to build a lighted tail for them.
I did this a long time ago. I have to pull them apart and tell u on weekend.
From memory, i had to trial and error with different types of resistors to get the LED lid evenly without affecting the driver and i didnt have to use bleeder resistor.
Last night I made a EDC for a collegue of mine who is a fan of my flashlight hobby. It has a lighted tail and because not all combinations of led. driver, bleeder resistor, tail resistors and tail leds, work well I tend to post them if I did a succesful build. Here are the numbers that I used on this light and that work very well and do not disturb the user interface. It has a 6-led ring with red 0805 leds under an orange tailcap that give out medium bright light: already well visible in low light conditions and visible at a distance in the dark.
-it is a S2+ shorty with Aspire 18350 battery
-Luxeon V led on a DTP board
-BLF-A6 driver with 470 Ohm bleeder
-both springs bypassed
-Lexel tail ring with two strings of 3 leds, for each string a 10K Ohm resistor
–6x red 0805 leds
First I tried it on my regular 6x Tail boards with conventional 6 Balance resistors and a 1kOhm Bleeder
Main Problem was that with low battery voltage the higher voltage LEds (Blue, White, pink, ice blue) get dimmer tan the low voltage ones (red, yellow, green)
I came up to enhance this idea with a voltage regulator, but had to do some steps to make it work
first get the voltage and resistor value for each LED at the same brightness
Then I made some calculation to get fixed current draw versions
It is also possible to use this with side switch lights like Convoy L6, as I can get the parasitic drain for the 18kOhm bleeder down to 0.4mA when the tail board has 0.15mA for the LEDs
Now the first 4 Prototypes
I did quite some measurements and tests to even out the brighteness of them
Firt L6/L2 prototypes are build and successfully tested on my bench, modding the lights will follow
One tme i skipped the very current hungry Emerald green for a warm white
The tail board itself uses a voltage regulator so the brightness is constant down to 3V cell voltage and can be fitted with 1S or 2S voltage regulator
The 2S Voltage regulator has a 0.1mA higher drain
I haver also ordered fitting 3x3mm trimmers so that the brightness of the board can be adjusted for 2V and 2.5V LEds in 2 groups
On the other hand I can also build em with a current draw from 0.15-1mA with the balance resistors without trimmers
have made a 4x4 cross section board for 2 channels in cross pattern
The rainbow LED boards have one drawback which are the inefficient Emerald green and yellow LEDs,
so their brightness is lower than green or white LEDs at the same current
Could somebody list me all the components I need to build the Rev6 illuminated tailcap including the type of LEDs with the metal Convoy S2+ button? I'm new so I found the list it came with a bit confusing. Any help is appreciated.
I got mine from the same seller on ali express. Got it in not too long and it had a omten switch. It did mess with mode memory with both my mtn electronics driver and blf a6 driver. Need to figure out what resistor to get.
i have a quick question I suppose in the same realm of tailcap lighting. On the emisar d1 driver there is a unused pad for an indicator light, or other device but indicator is what im after. What type led should be used and how would I go about doing it for the e switch?
I do believe you are most likely right. I just recently obtained the d1 and upon looking through this site found a post that revealed that info. So I wanted to do that modification if it was able. Oh...and it's an honor to have you reply to my post. I've watched and read most of your posts and YouTube videos
Do people actually watch those video’s? I should make more then And it is a good practise here on BLF that new members are helped out with stuff, for we all want more flashlight lunatics, makes us feel normal
[/quote]
[/quote]
Yes, i did watch them when i was researching led emitter reflowing I also seen the blf a6 triangle fix. I believe that is what it was
It was a bit of fiddling around, but I finally got my illuminated tailcap working on my just modded Lumintop AA. New EDC is born :sunglasses:
What I used eventually:
*Lexel’s 15mm drvr with BistroHD. Had to be sanded down just slightly.
I Added 1*2.2Kohm (SMD 222) bleeder between + and middle of an AMC7135. The AMC had to be replaced, since the middle paws were missing on the ones from Lexel. I assume for clearance to the + terminal. Adding a bleeder over C1 is easier I guess, but I had already glued the driver on the pill. I wasn’t aware that a bleeder was needed on this driver :person_facepalming:
*XPL HI on noctigon star
*17mm Illuminated tailcap from fasttech. Replaced the leds with 2*0805 red’s and 2*473 SMD resistors.
The transparent spacer had to be sanded down a bit to fit.
*Green transparent tailcap from kaidomain. Nice transparency and no problems with tailstanding.
*Keeppower 14500
The tailcap is perfect for finding your light at night. Basically invisible in daylight. Just how I like it.
I couldn’t measure (0.000A) any current through the tailcap, so it’ll last at least 2,5 months on a full keeppower.
I’d like to make a couple of single AA lights with illuminated tail caps for my young kids.
Apart from the Tool AA (thanks Dutchee) can anyone recommend a single AA or three AAA light that takes s 17mm Switch PCB?
I’d prefer no strobe and not too bright. I was originally planning to give the single mode SK68s (with a resistor in series with the LED, but I think they have press-fit switches.
^ mind that a lighted tail the way it is done in this thread only works on li-ion cells because there is no voltage boosting for the tail leds going on. You might get away with a 2xAA light and red tail leds.
Here's my take on the lighted tailcap - a simple version (no microcontroller required!) which has two groups of LEDs and two configurable threshold voltages, for example 3V and 2.7V.
When the voltage is above the first threshold, the primary colour lights up (e.g. Blue). When the voltage is between these two voltages, the 2nd bank of LED is switched on and the first switched off (e.g. Red) - this can act as an indicator to recharge your battery! When the voltage falls below the 2nd threshold, both LED banks shut off to increase standby duration.
Also while at it, why not convert your switch to a FET switch instead?
You can achieve single milliohm switch resistances depending on the FET used. The FET board has an onboard tiny rechargeable battery, so servicing is not required once installed! This may be useful for those wanting to increase the durability of the tail switch, esp. on lights with high battery currents.
Please feel free to check out this thread for more information, including OSHpark projects so you can make your own:
