We are almost ready for some beamshots in the Belgium Ardennes. This GT is a great light, whatever the corona or hotspot looks like, the long shots are showing what this light is capable of. The comparison between the GT’s is part of the hobby, not criticism on the GT or it’s designers and producers. Wednesday we can do a comparison of three GT’s, when Megabassie arrives at the scene. Maybe now some folks understand why we are happy the GT’s arrived just in time before our holidays. In Amsterdam is not so much room for large beamshots...
Both of my GT’s centering ring bars were trapped by the hold down screws to the point that they had to be pried off. I opened them up till they floated on the hold down screws. As you can see in this picture, the hold down screws are narrower as compared to the centering ring bar clearance holes. This could cause the centering ring detail, not to sit flat due to the interference, how is it supposed to sit Flat when it’s trapped between the screws, this thing should float to allow the reflector to center to the LED, and the mcpcb hold down screws to the centering ring detail should act as a anti rotate.
The centering ring bar measured 2.48mm thick all the way across the board, regardless of the warp on both of my examples, and now measure .012” thinner since machining it. Now in my case, I’m running a clean de-domed XHP35 HD E4-1A, and during the course of tuning the reflector to the clean de-domed LED, I had to move the reflector up .004” to gain the highest LUX measurement at 20M. I made shims out of Precision Brand Plastic Gauge stock.
I made quit a few, of different thickness’s because my other GT is running a XHP70.2, so I played around with Focusing this 70.2 LED too. Now all this has changed a bit again after doing Endermans Tuning Procedure.
So Jason if you need a shim to get your GT back in focus, because .500mm is a huge difference, let me know what size/thickness you need, I have quite a few extra!
I’m just guessing .500mm. It might be closer to .250mm. I didn’t bother to measure. I said screw it, let’s just flatten this sucker and see what happens. Lol
Just made some first long distance beamshots with my dad. This light is sick. Almost no difference with long beamshots.
My registered packets came here.The first,passed below Customs radar,but for the second,they ask PayPal receipt so as they set it free for delivery.I will send Neal’s August advance payment of course.
I just measured my hotspot at exactly 3 m from the lens, i measured just over 13 cm, so 13/2,54=5,11” so i think i’m good
Has anyone tried putting a hotspot on clouds? I think the lowest cloud types are around 2000 metres.
Hi again!
Just an update: received the head today.
Package badly bruised AND wet.
But it´s ALL GOOD!
No scuffs or marks, only a tiny spec on reflector, glass pretty clean etc.
Boy it´s huge
I went out despite it´s –28°C now.
I tested it towards a road and a truck was driving a bit away from me in slight angle.
It just casually threw 920 meters. I was like “Ooops, better watch out where I point this…”.
That was with fogged glass AND some light snow/hale in the air (glass often gets fogged up in here when it´s cold and you take your lights out from inside the house).
Boy –28, that’s cold!
Size does matter, doesn’t it? :sunglasses:
(With the GT, that is)
I am 1288 on buylist have they sent a email out on where to pay yet for my GROUP?
Just check post one. Right now it’s Chinese New Year. Once China goes back to work Texas_Ace will let us know when he will send out the PM’s. So late Feb or early March.
Thanks
Thanks
Thanks
How the two pieces of the GT were declared for the Customs please?
Lumintop already went to work, you said to remind you about the incorrect track number.
Flashlight was sent and received in the US, not in Kazakhstan
My GT arrived on thursday, and it truly is awesome. Both packages were quite moistured and the lamp itself also had some moisture on outer surfaces and inside the tube, but otherwise in good condition. Also got the batteries with the lamp, and thats really great, because ordering batteries to Finland has been impossible for the past few months.
Great work from the BLF GT crew and all the people that were making this possible
Thanks!
Man, it sucks they got wet. It’s like they got left out in the rain or something.
Lumintop needs to get their registered mail boxes sorted, as well. Some extra padding around the head is definitely needed.
Anyway, here are a couple of pics of the head taken apart for those interested. I added these to post #3.
Btw, this is my light. It’s got a different switch cover. Stock is black.
