I just bought a bottle of this same Radio Shack Precision Lube today, and it's great. I did a little research and lo and behold this is "Super Lube" oil. It's even got a "Synco" pocket clip on it. I assume Synco (makers of super lube) sells it to Radio Shack and then Radio Shack slaps their name on it. They call it "Needle Tip Precision Lubricator". It cost me around $3.99 for a 7ml bottle.
my superlube oil works extremely well on (any kind of) o-rings and anodized threads.
it kills friction in bare aluminum threads (e.g. Quark threads) but doesnt really reduce abrasion (build up of "grey crap" is still there)
on titanium threads it doesnt do anything noticeable. i even get build up of the grey cr*p which i dont seem to get with other/no lubes. thats why i dont recommend superlube oil on titanium threads. maybe superlube grease works better on Ti threads.
I thought I remembered hearing it was on a CPF thread once. Works pretty good. I remember hearing this being the best low cost option since it was compatible with most of the metals and rubbers in lights.
Unfortunately not carried at all retail locations. They also carry a Anti-Corrosive Lubricant Spray which I have found useful. Like WD-40, but leaves a slight oil film. It has help me unstick a few pills/switches that seized up.
Hmmmm, not sure I agree with that assessment. I clean threads with mag wheel/aluminum cleaner before I apply grease or lube. Doesn't matter, threads still turn grey regardless.
i had asked the superlube company about the grey buildup in the suberlubed non-anodized bare aluminum threads (e.g. in Quarks or Klarus P1A) suspecting that the superlube oil would dissolve the unprotected aluminum and the answer i got was:
and yesterday the maker of Nano-Oil (a substance which i assume works a little better on unanodized aluminum threads) who is wary of making any kind of promises regarding the performance on unanodized aluminum threads commented:
Re: Comprehensive Grease and Lube Thread
Originally Posted by Nano-Oil.com
I do agree that my response was cryptic to a level, I do apoligize but there are reasons, I cannot & will not promote Nano-Oil in CPF ex: I always use the verbage "use a good anti friction lubricant of your choice"
From google cache one can see that 1 or 2 years ago he was selling Nano-Oil on cpfmp but then he stopped the dealer's subscription on cpfmp. In any case, as far as i can tell the original problem of
unanodized soft bare aluminum threads (male rubbing against female)
is still unsolved. But it's good to know that superlube does not dissolve the material. As stated earlier, superlube does kill the friction in the bare aluminum threads. Feels really good and smooth. (Not so good on Titanium threads, though). No wonder that nobody wants to promise anything or promote the oil further on CPF: we flashaholics are highly criticial (some with asperger's) and much of our Chin*se threads are just made of cheap aluminum quality. I'll continue to assert and promise that there is no lube on earth (< 20$) which solves the original problem to kreisler's satisfaction.
With typical lube (superlube, nanooil, silicone oil, etc.) we will always end up with grey crap in our unanodized aluminum threads. Simple as that. It's maybe comparable to the example of stainless steel kitchen countertops: when you try to clean/scrub the kitchen counter with a dishcloth, the dishcloth will end up grey from the stainless steel abrasion.
I really wouldn't worry about the grey gunk! You seem a little too concerned about it!
It will not effect the threads in anyway and the lube will still do it's job even if it's a different colour. The only slight annoyance is when you place the light down during cell change over, the discoloured lube will leave a mark (if your not careful) on surfaces.
I use silicone RC car shock oil and or grease. I had a bunch of different thicknesses from years ago. Everything from really thin oil like to grease. I put on what I think I will like, if I dont, I wipe it off and put on a different one. You dont need PFTE or anything like that since there is no friction. Thickness is key. Each light responds different to the thickness. Any petroleum product will mess with the o rings.
