Yep! Very comfortable to hold. Super crazy long run times on 26650’s (I haven’t charged the battery yet and have been using it tons!). Love it. After I cleaned the LED and painted the internals black, it works great now
Have you seen the picture of the reflector on ebay? It's got fingerprints all over it! Must come as standard, instead of putting a little sticker on telling you who built the light, he leaves his fingerprints and DNA all over the reflector. Cool!
I took measurements of this flashlight, not sure if you can find similar measurements for the Z5
Talking about wide flood beams, I've been using this flashlight (lots of discount codes available for TomTop) without the front lens and bezel and DAMN does it have a wide flood beam (132 degrees!), nice sharp cut off, and flawless beam quality :) I love it so much ;)
The pics below were taken with the flashlights 3.75" from the wall, and with my new "flood" configuration the flood beam was a mind blowing 17 inches in diameter!
I got two Keygos M12s. I am a newbie so bear with me. I got a charger and 2 Keygos 26650s batteries too. All my flashlights are for bicycle applications. At first it seemed like the zoom would go to beam when I had it mounted. Another poster recommended getting another O ring. Anyway, I laid them on the side for a while, and used my Ke-5s and Ke-1s.
Enter my bicycle helmet. Oh boy. I have been using smaller lights. Then I decided to use a Ke-1.. Then I noticed the mount could hold the M12 on my helmet. I mounted the M12 on my helmet and oh boy.. That is where I need a beamer. With the two Ke-5s or 1s up front and the M12 on my helmet, it is perfect. I can reach up and put it on floody, but the beam is much better. Pointing at where I am going.
Haven't measured the runtime with the Keygos 26650, but I was on high for about 45 minutes, and still running strong. Result, out of the 10 flashlights I got, the M12 is the brightest and the best. I am wondering now, how would the Keygos M10 be.
The M12 is rated by the maker at 1600 lums. I got another flashlight that also rated at 1600 lums, but runs off a 18650. The M12 is brighter..
