Best clicky AA Flashlight for EDC under 20$
I see that Lumintop AA has PWM on low and medium and it’s too weak on Ni-hm. Sofirn SF14 shows very good choice. 230 lumens on high are real?
Can’t beat any of those suggestions. I have a TG06S and really like it. The Sofirns are on my Amazon shopping list for my next purchases.
SF14 trick all your requirements for only half the price you want to pay.
SP10A/SP10B.
SP10b has annoying “long click for off”, SF14 is a conventional reverse clicky light
It’s the shortest “long click for off”, I’ve seen. Very short hold for off, maybe a half second. Same for on.
I prefer reverse clicky flashlights over side switch for edc becouse of parasitic drain
I recommend the Sofirn SF14 a lot
But I’d avoid the SF12 (bad driver, bad pwm, bad tint, bad machining)
The only thing I wish the SF14 had to be the perfect EDC is a clip or tube that could be reversed for use attached to a cap, it’s perfect otherwise
The Thorfire TG06S had a reversible clip, tailcap switch, good output on alkaline though it kicks butt with a 14500. High(500LM) -Middle(200LM) -Low(50LM)-Moonlight (1LM ), and Strobe(500LM); When powered by AA battery High(150LM) -Middle(80LM) -Low(20LM)-Moonlight (0.5LM ), and Strobe(150LM)
Sofirn shortened the longclick from the 0.5s (SP10A) to 0.3s (SP10B).
Entirely tolerable, after getting used to other lights using longclicks for on/off.
Tg06s has bad pwm and I gave away mine.
I understand it isn’t a “long” click, but I always stay away from lights that need more than a inmediate and quick single click to turn ON and OFF
from what I read, exactly like it’s clone, the Sofirn SF12
Wellp, if EDCing a light like that, it’d be turning on, off, on, off, on, off, etc., in your pocket all day. I’d rather it be that much harder to accidentally turn on.
And having to lock it out, whether physically or electronically, is even longer to turn on than even a longclick.
Besides, on the ’B, a fast doubleclick goes right to turbo anyway, and a shortclick off.
Another vote for ThorFire TG06S min flashlight. You can check my top favorite and the best aa flashlight My Favorite Top 10 AA Flashlights in 2023 (Better Than AAA) list. Most of them are affordable.
I read the reviews about the pwm and did not notice it (I could see the rainbow lines when watching media on projectors) so I bought it because it was less than $10. It’s my current EDC until I can get my Thrunite T10T working again.
I have many clicky AA’s, (Sofirn SF10, SF14, Lumintop Tool AA, Thrunite Archer 1A V3, etc) and in my opinion the best of all is the Acebeam M10
The sofirns and Lumintop are a “toy”, they can only sustain like 100lm, whereas the M10 pushes 200lm constant when using NIMH. The Thrunite is nice but it’s so big, nearly 18650 size
Utorch UT01
Does NOT come on in pocket
400 lumen at least with 14500
low is about 5 or 10
i really like it
very small, well made
no pwm
decent UI
light color is a little coolish
i got mine under $10
wle
Isn’t quality control horrible on that light though? I keep reading constant complaints about the switch breaking, otherwise it would really appeal to me.
I am for Sofirn SF14.
