2x Convoy S2+ Blue LED Flashlight Host Shell For DIY
2x Convoy S2+ Red Led Flashlight Host Shell For DIY
2x20.5mm x 1.6mm Ar-coated Glass Lens For Convoy S2/S2+/S3/S6/S8 Flashlight
not more than once
not more than once
use the link and code from this nice page:
https://m4dm4x.com/convoy-20-off-for-friends-and-family-2/ :D
That looks very good, I have ordered
thanks Martin.
Thanks M8 :)
Just grabbed an EA11, thanks. Any idea when the Imalent HR70 will be in stock? Interested in getting one of those
Thanks Martin
ready to preorder
be fast before its sold out again!
Just pre-ordered one using your link and code. Thanks! :+1:
does this make a sense?bad cooling…what do you all think about this new imalent? its crazy…lets say useless….or? btw.chinese new year is over?
Banggood say that the HR70 has been ship to me today. :sunglasses:
but I’m very confuse… one guy on reddit had the HR70 and it DIED in several day…!
Any chance of getting a code (better than 20% discount) on the following flashlight?
Astrolux S42 18650 Version 4xNichia 219C/XP-G3 2023LM USB EDC LED Flashlight + INR18650 30Q Battery
M4D M4X,
Now that CNY is over, any chance you can swing a code on a 365nm UV light? It seems people around here like the Convoy, I’m not sure what else is on the market.
i am already poking ...
Hi Martin, just ordered a Rofis MR70 at Banggood. :+1:
Is there any more information regarding the Lumintop ODF30?
Pm sent Martin…thanks
€U warehouse! (less than 100 available!!)
Code: GEDX80
price: € 178,98
Main features
● Using of high brightness 8pcs CREE XHP70 LEDs with 32000 max luminous flux
● Ultra clear toughened glass lens, the light transmission is up to 99pct with scratch and impact resistant
● Waterproof level up to IPX – 8 ( 2m submersible ) the flashlight can work normally even in heavy rainstorms
● The shot distance is up to 806 meters with wide beam range
● Built-in battery pack includes 8pcs 3000mAh 18650 Li-ion batteries with high discharge performance
● Intelligent temperature indicator, when the body’s temperature is up to 50 Deg.C, the LED display flashes 8 times for 30s to give a warning
● When the body’s temperature is up to 50 Deg.C, the light will automatically adjust the current to keep the flashlight to work under 50 Deg.C
● When the battery voltage is under 13V, the battery symbol will flash 10 times per minute to remind user to change or replace the battery
● 5 common mode: 120Lm, 500Lm, 1500Lm, 5000Lm, 13000Lm
● In any mode, double press the button to enter 32000Lm turbo mode, double press again to enter strobe mode
Hello my dear friends!
march starts with a groupbuy and some nice deals:
as always you can find the codes here: M4D M4X DEALS
Miboxer C4-12 ordered !
Thanks
today i can offer you a new presale deal for the:
Features:
-The head and body of the R2 flashlight are connected by a stainless sreel central axis,the head can be rotated and beam angle can be adjusted as well.(As illustrated in the picture).
-Accurate 45-degree inclined plane;90-degree and 180-degree position;Stainless steel center axis connection;10000 rotation tests.
-Angle surface with non-acute angle design,rotates smoothly;
-Ergonomic rotation design,one-hand operation.
-When R2 is used as headlamp,the user can put into silicone head caps without removing mental clip,which is easy to operate.It would work better with tail cap removed.
-According to the position of the switch and the rotation direction of the head,it is recommended that the user use right hand to press the switch(Put the switch stay towards right above and rotates head into appropriate position to procide lighting).
-With magnetic tail cap,metal clip and adjustable-angle head,it can achieve hands-free operation and procide accurate lightig.
-Battery power detection and low battery power reminder.
-Magnetic USB charging.
-Magnetic base connector supports cttachment to metal objects.
Package included:
1 x Rofis R2 XM-L2 U3 700LM 7Modes Brightness USB Rechargeable LED Flashlight Headlamp
1 x 14500 battery
1 x Headband
1 x Clip
1 x Charging Cable
1 x Lanyard
2 x O-ring
works with 14500 LiIon cells (included) and in case of emergency also with AA NiMh or Alkaline !
Code for C4-12?
Got a code for LiitoKala Lii 402?
