Yes amazing, is there anything sir CRX can not do! :sunglasses:
Thanks mate :+1:
I hope not :+1:
Detailed and simply awesome build. :+1:
As always CRX, your builds are over the top .
Love the build quality, but I’m not so fond of the most striking element….optics.
Have you considered adding some reflectivity to the optics sides? Not it looks like you have light running out and banging on the body sides…maybe even a white paint would help? The way it is, is it really any brighter than a single LED?
Thanks mate.Yeah I knew this before I made it, not the best use of the triple setup like I said in the OP.
Maybe even a straight mule would output more light but I wanted a triple and a bit of a focused beam from this.
I did polish the optic sides back up, paint or mirror tape would not really be possible here but I’ll have a think about it.
Like many of my builds I’m not always looking for maximum efficiency, just seeing if it can be done :+1:
Another sweet build :+1: I like the look of this one even with the odd looking optic
You never cease to amaze , CRX .
Great build and thread .
NIIIICCCEE———- I always enjoy your builds —- learn little tricks—— now to go build something
Superb :heart_eyes: True scratch-built EDC :sunglasses:
Any beamshots?
Ive been thinking of a build i wanted but wasnt 100% on sanding optics down, your beamshot seemes quite good. What was the original diameter and how much did you take off?
Thanks
The original diameter of the optic is 20mm, I took it down to around 15.3mm.
Liked stated above, it is not the best way to use these unless you’re just wanting to build a wee unique light for yourself, there will always be artifacts & light loss.
Here’s an image of the approximate sizes from the parts box.
Thanks for the info, and again amazing job. Has me inspired to move forward on my project.
CRX, indulge my ignorance, but the TIRs are “blackened” for any particular reason? Does it help to eliminate any kind of “beam artifacts”?
Great great work, once again :sunglasses:
Yeah these are from years ago, I was experimenting with them.
I think it’s better to polish the sanded down outer edge than to blacken it
The black on the bottom of the legs is just for effect.
