Thanks for the review. I ordered one a few weeks back. I also picked up the KF8 Xhp50.2 that should be sweet. But they are still in transit. Thanks
Thanks for this review! Just came across this “new” P60 flashlight in KD and found your review. I’m considering the host version.
The first thing I thought of when I saw this, was if it’s an upgrade to the Solarforce as far as thermal transfer. For as long as I can remember the issue with the Solarforce and clones was there was some open space inside surrounding the drop-in. It was a common mod to fill the space with strips of a soda can or copper, aluminum tape, etc.
I always thought why doesn’t someone just make a host that fits the drop-ins tightly without the gap? But maybe that’s not possible?
If it is I hope KD thought of that when this was designed.
I received my E6 host. I definitely like it. The amount of space around a drop in inside the head is probably approximately 0.5mm (so 0.25mm on each side). About as tight as it could get and still accomadate all drop ins.
I have a lot of drop in modules and Kaidomain Kdlitker’s are by far the best and brightest for under $30 and these cost $10 which can’t be beat.
The XPLHD SMO and op are brighter for flood and throw than any drop in I have, brighter than my S2+ and as bright as my XHP50.2. I am extreamly pleased with their drop ins.
http://www.kaidomain.com/p/S026671.KDLITKER-P6-XPLHD-Cree-XP-L-HD-White-1000-Lumens-3V-9V-2-Groups-of-3-to-5-Mode-SMO-P60-Drop-in
I am swapping all of my drop ins to Kdlitker’s. No I don’t work for them. Just a flashlight guy, Dad, husband, and hunter that lives in the woods.
Thanks for the info, so I guess their has to be some gap/space on these hosts to be able to accommodate different drop ins. Yes .25mm around is a very small gap, but a gap is a gap so no heat transfer there. Are you wrapping your drop-in’s for the E6?
Also where to get the E6 host for $10? (I’m seeing $13.99) does KD offer a BLF discount?
Thanks for your feedback on the KD XPL HD dropins, that’s exactly the one I decided on last night, only the 5000K NW version. I’m also curious for the XP-L HI version, I’ll probably get the XP-L in OP and a HI in SMO.
I wonder if KD will come out with an XHP35 / XHP50 drop-in too.
Many of Kaidomain’s Kdlitker P60 modules are $10. Their P60 host, the E6 for 1x18650 only, is $13.99 and their E6 host that comes with the extension that can be used with the tube for the 2x18650 use or without the tube for 1x18650 is $15.99.
I am not wrapping my modules. The light does a great job with transferring heat. They really stay cool. Now my S2+ XPL hi gets hot in under 5 minutes.
I’m happy with it.
Thanks Funner, OK I see, I thought you wrote the E6 cost $10, now I see it was the dropins, sorry, my eyes were deceiving me from sleep deprivation!
I did find a discount code for KD, kd5off for 5% off, its not much but better than nothing.
EDIT: The code only works on items that aren’t already discounted, so it won’t work on the E6 hosts because those prices are showing as a “Discount price”
Same goes for the XP-L and Nichia drop-ins.
When a flashlight gets hot, in one way its a good thing… means the heat is transferring away from the LED and into the body, making the body a heat sink to take heat away from the LED.
No offense meant, but this is pretty much a contradiction of terms. If it did a great job with transferring heat, it wouldn’t stay really cool.
For the P60 lights the body won’t get hot because the heat stays in the dropin (poor heat transfer to the body due to the air gap) that’s why people wrap those dropins. For the most part I think it’s not necessary with low current “off the shelf” dropins, but if you build your own hot-rodded dropins they’ll need wrapped.
I wish KD made an 18350 or 18500 tube for the it.
I wonder if the E6 will lego with Solarforce, anyone know?
Just noticed KD’s newer drop-ins are upgraded with large brass pill for better heat dissipation, nice!
http://www.kaidomain.com/Search/SearchResult.New%20KDLITKER%20P6
I just turned it on for a couple of minutes until it warmed up. The heat transfer throughout the upper half of the body vs my S2+ which the heat is in one spot. Which makes it more difficult to notice.
After it was on I then pulled out the drop in and the heat was the same as the flashlight body.
I will put the drop in in another light to feel the heat transfer.
The E6 host seems to spread the heat out through the whole end of the light.
Every time I use it it has been outdoors where the temp is 20-40 F so that helps to keep it cool and that is why I noticed almost no heat.
One thing I have noticed with the E6 is if. You jar, shake it, tap it hard, or tap it hard on the counter it will change modes.
I would think stiffer springs would resolve this. With 2. Batteries it is more likely, I think because the more moving weight of those 2 vs 1 battery.
I will see if I have some stiffer springs or make a double spring setup. I did try stretching the springs a bit and it seemed to help, stretching a bit more would probably help. Or adding a copper spacer with nylon outside would tighten the tension on the springs helping this.
Still like the light though.
Great, thanks for the testing, sounds good!
Are you using a flat-top/short/unprotected cell, or a longer button-top protected one?
Maybe blob some solder on the end of one spring?
Or a magnet on the cell?
Also do you have any Solarforce lights/host to see if the tubes/threads lego with the E6?
Pretty sure they don’t LEGO
Tried the solarforce ring guard tail cap and it doesn’t work.
There’s a gap of almost a cm when you screw the head on the front end too - the light still works but the kdlitker when on a solarforce body the p60 globe moves around.
It might be amusing to try one of the silly solarforce attack bezel rings on the front - I will maybe give it a try later today after I wake up if I remember.
do you know if these hosts are compatible with p60 heads, tailcaps and bezels?
They aren’t compatible with solarforce stuff.
I don’t have any surefire lights to test them out with sorry.
I just bought the e6s, and I am getting ready to purchase batteries for it, the batteries that they sell On kaidomain are 69mm, would it be okay to get batteries that are slightly shorter (like the 30q buttontop) or should I try to shoot for batteries that are round 69 mm. Ty for any help!
I just purchased the KDLITKER E6 with triple (individual colour) XP-E drop-in (I chose red, blue, and amber options) and have to say that it is an amazingly good value for money light. About 50% brighter than the RGBW Ledlenser P7QC, but at 25% of the price. A review will be coming soon!
I’m thinking I should pick up the new 21700 version of this. Put myself together a high capacity EDC tube light. Looks perfect for that. I already have a bunch of drop-ins. Perhaps I will de-ano it too.
Just be aware that there is no tactical ring for the 21700 yet, do if you need that (I do to stop the light rolling) you might want to stick with the 18650 version.
I’ll probably just make some kind of lanyard that I can use to prevent it rolling. There’s no momentary on with the reverse clicky, so I don’t really need the tac ring for that. I wonder if the tailcap would take a McClicky?
