I’d prefer around 4500K, but anything in the range of 4000K to 5000K would be okay with me, as long as it doesn’t have a sickly tint. High CRI would be nice as well. If you’re going out in nature, you might as well see it as God intended!
Any chance you’d also consider making a mini version to hang in tents?
Something like single cell (AA or 18650), candle to incandescent temperature range (~2000k), lightweight, 360* diffuser, cheap. Should include some kind of clip or ability to hang it to a tent ceiling loop.
I don’t understand why people want lanterns in the 4000-5000k range. That introduces blue light which is artificial and will make it harder to sleep because it messes with circadian rhythms.
Like DavidEF mentioned the XP-G3 may be a good emitter for this. ( in the 4000K range to get the best balance of tint & output. Also maybe the XP-G3 would not get so hot as an XP-L on 1.05 amps ( three-7135s) after a hour? I never tested that LED yet… The run time would still be not bad on maximum-mode at 1 amp if four 3200mah or higher cells are used maybe.
I did that exact mod to a Roche single 18650 flashlight, put a 2700K warm white XM-L in it, with a 3-7135 Q-Lite, and a frosted diffuser. Its the perfect tent hanging light.
He is correct on that, warmer tints closer to that of a candle or even yellows, ( 2300 ~ 2700K) does help people sleep & be more relaxed at night. What You Should Know About Warm Lighting
Also updated the interest list. I will be working on the modification to the prototype this weekend coming, and will keep all the recent tips in mind in the upgrades, ( including that it will use simple common 16mm stars for easy modification or LED swaps by everyone. ( it will get modified form the single emitter to two, and a single center bolt-post, and a frosted main lens ( to eliminate the internal lens to cut costs.)
As we all know… TheMiller has been MIA now from BLF for over 2 months… and he was a key team member who had the expertise and contact abilities to communicate with the manufacturers on building our special lights, and he did suggest Thorfire as a good candidate, also Lumintop (who builds our GT) may be another possibility for this ultimate lantern. If TheMiller does not return, we will need help form a member who has the ability & time to be that link to manufacturers for us.
Was talking to a builder and he wanted 10 of these light once I showed all the benefits. He have seen my other light but this light fits was he needed. but Sadly I think it takes to long before its in produktion so he have to go elsewhere.
Many of the third-party hosted pictures in the early parts of this thread have been ‘unlinked’ by the hosting provider. Does anyone have current (or a pointer to updated) pictures of the prototype so far?
