I’ll add interest for one so this is more likely to happen
Interested in 1
Interested in 2
I would like to get 2.
It seems no one wants to do it, so after some calculations, I think I could make batch of 4040/5050 boards for 4€/piece + shipping.
2mm thick copper DTP,38mm diameter, 2oz copper layer, gold plated top layer, nickel plated bottom surface (just as good as gold for protection from oxidation and easy to lap/polish).
For "group buy" (single payment,single shipping address) price for 50+ pcs would be just 3€/piece.
This could be good option for USA buyers, to reduce not just PCB price, but I suppose domestic shipping is cheaper too.
For standard orders via my webshop shipping would depend on quantity since these boards will be quite heavy, around 20grams each.
Estimated shipping prices:
Priority airmail (non-tracked):
Up to 50gr - 1,97€
51 to 100gr - 2,97€
101 to 250gr - 5,97€
250 to 500gr - 9,97€
Registered airmail (tracked):
Up to 50gr - 3,97€
51 to 100gr - 4,97€
101 to 250gr - 7,97€
250 to 500gr - 12,97€
Packaging envelope is 10-20gr.
Since I don't own Q8 (not a fan of sup cans), I will need help with exact dimensions, I'm also a little bit confused regarding screws,some pcb renderings have it,others don't.
I would like to see interest, around 100pcs would be minimum, I think current list is close to that.
4040 footprint is compatible with Luxeon V, and Luxeon MZ,Luxeon MX, 5050 for SST-40,XHP50 etc.
I will have boards with 4000K Luxeon V soldered as option,of course.
Luxeon MZ is available as 3V LED and 5700K 90CRI at Mouser and Digikey.
I know that this niche is too small to be worth creating a PCB, but I’ll mention it anyway, just to float ideas that may get useful in another time in another place.
I’d be interested in a PCB created specifically for Luxeon M/MZ/MX.
It would be different from a Luxeon V one in that the pads should be shifted somewhat to the centre and rotated 45°, to focus the reflector on the outermost dies.
This should remove the hole in the middle of the beam, resulting in a nice, bright, small hotspot surrounded by large corona.
Great initiative! The Neal route stopped at the point that it became quite confusing already. I do not regret atm to not continue that route.
I hope that someone already has precise dimensions, or else I will open up one of my Q8’s this afternoon.
Good to hear someone is picking this up, I still want to put xhp50.2’s in mine.
Far as the pcb design goes, the final design I made should be what you need. The earlier designs were based around the prototype Q8’s and are not relevant anymore obviously.
PM me if you would like help with this, I have the source files around here someplace.
I would be in for 2 of these boards.
led4power I appreciate your initiative A LOT! I’ve been waiting and hoping for this to gain traction, but after it being quiet and having no convenient way to split things up amongst ourselves I was growing worried.
You can add me for 2 more boards (total of 4)
Thanks, but I only need LEDs/screw holes etc. positions, I will make gerbers according to my manufacturer spces/rules.
Should I open new Interest thread? Because I'm not sure how relevant is current list, there is possibility some members gave up after lack of activity in this thread.
I think that if the board is available, people who are in the list will just pick up their Q8 and start modding it. And I think that with the first succesful mod come new people buying the ledboard. Especially with ready mounted Luxeon V’s, the mod is doable for many many people: instant 8000 lumen in good tint (well, if the center pieces are succesfully reamed :innocent: ).
I guess I will have to unsolder the ledboard on one of my Q8’s and do some measurements on the hole positions. In TA’s design the two small screw holes were dismissed because they did not fit in the 4040/5050 double design, but who knows you can squeeze them in.
Would it make sense (or even be possible) to use rotated LED pads?
All fresh measurements on a production Q8 board:
Thanks!
What are those two smaller center holes for?
They are for the led wires.
The two small holes further out screw the board onto the shelf in the first production run, in the later production run they allow longer screws from the underside of the shelf through the ledboard into the reflector (clamping the board between reflector and shelf). In both cases they prevent twisting of the board when closing the bezel. If you leave those holes out, clamping of the ledboard to the shelf is leftover to the bezel, while risking twisting the board with closing the head. It will work but it requires some care when closing the head.
Central hole is used to clamp PCB+reflector to body?
