I definitely agree that Andúril is worth the effort. I put it on my Q8, and I liked it enough that I am performing (well, attempting) surgery on the Emisars shortly after getting them.
I’ve tried using a thin pair of steel hemostats with rounded tips to push on the driver, using a lot more force than I could exert with the wood skewer. None of the three will budge.
Looking at that photo of a D1S, it looks like there’s a film around the outer edge of the driver (where the vias are). You don’t think this was glue? If there is glue, I wonder if putting them back together and running them on turbo for a while might weaken the glue?
The drivers are glued. To get them out I used a very small metall stick with flat ends, passed it through the hole at emitter side onto free space on the PCB (NOT on top of components) and hammered it very carefully.
A plastic rod or toothpick usually works, with some careful tapping from a hammer or something. I’ve avoided using metal for this though, to reduce the chance of damaging the driver.
My “older” D4 that has the first Noctigon 4XP V1 MCPCB, the driver came right out. Had to use minimal force with my plastic poking device.
The newer D4 that came with Noctigon 4XP V2, had the driver glued. I had to lightly hammer it out with my poking device.
As everybody else says, mind the thin white wires to the e-switch, they are short.
But now i have two “new” D4’s. One with NarsilM 1.2, and one with Andúril :heart_eyes:
I was able to get the drivers out of all three Emisars. I made all three of the changes below at the same time, so I don’t know for sure how much each of them contributed to the success:
I used a blow dryer to heat up the driver.
I carved a chopstick down so it just fit through the hole in the head - this was sturdier than the skewer I tried previously.
I used a pair of pliers to tap on the end of the chopstick.
Unfortunately, the D4 driver was damaged in the process - I broke off the R5 resistor. Having no SMD soldering experience, I didn’t have any luck reattaching it. After a few tries, I noticed that both the end contacts had came off the resistor, which means there was nothing for solder to stick to. You can see one of them still on the solder pad in the pic below, on the right pad.
I contacted Richard at Mountain Electronics, and he had a single spare driver on hand he was willing to sell me, so I will be getting the light going again soon. Richard mentioned that his MTN-22DDm driver works in the Emisars as well - good info in case anyone else breaks something removing their driver. Richard mentioned he had some difficulties getting the drivers out as well; he had to reflash about 150 lights from the first run of the D4, and he ended up with 4 non-working drivers.
The D1 and D1s are both running (a slightly tweaked) Andúril now, and hopefully the D4 will soon join them.
I wanted the ramping up from moon to start sooner, so I decreased HOLD_TIMEOUT in fsm-events.h from 24 to 16. This was based off the discussion starting here between you (TK) and goshdogit.
I wanted the max non-turbo level to be a little lower, so I changed both ramp_smooth_ceil and ramp_discrete_ceil in from [MAX_LEVEL - 30] to [MAX_LEVEL - 40]. (These are in the Anduril firmware file, roughly around line 165 or so, in case anyone else wants to adjust them.)
After using them for several days, I actually plan on lowering MAX_LEVEL down to –50 as well. I may re-flash the driver instead of getting the thumb workout. Even though I know that I can’t visually tell the difference between –49, –50, or 51, I’d worry I was off by a click and I want it to be right, dang it.
So I've had the same problem here, gentle add I could be, and actually reading this post and a couple others several times, I popped off that same resistor.
It's only a 4.7ohm, though. Does anyone know what it does? I bridged where it was too see if it still works, and from very limited initial testing of "it blinked on battery connect!" And "double tap to turbo works" and then shutting it down because it's all tore apart with no heat sink.. it seems to work. Thoughts guys? Do i try getting a new smd resistor from mouser? What package size even is this stupid thing? Or do I just put it back together (flashed with anduril of course) and see what happens?
I’m not sure, but I think R5 helps to stabilize power and prevent spikes. With a full battery, try running at just below turbo (or try a tactical strobe mode), to see if there are any spikes big enough to cause problems.
On older drivers, pushing too many amps through the FET would cause so much electrical noise that it would make the MCU reboot. Part of the fix for that involved adding a resistor which is traditionally called R5. I’m not sure if this is the same thing or not though.
Thanks tk for the insight! I’m gonna flash it and put it back together this evening, I’ll report back with how it acts or responds. I know it’s not a guarantee that it’ll not fry itself, but I feel a little more confident now. Nothing left but to try it, if it burns? Guess I’ll get a TA driver lol.
So I’m late here, but I did get it back together, and I ran the D4 through it’s paces with a fully charged battery, and it seemed to do just fine. I didn’t notice any issues.
I’m sure like you said, it was there for a reason. But maybe the rest of my components were slightly higher in the 5% tolerance range or something.
At any rate, if I end up with trouble I’ll post back here. But for anyone who finds this in the future, who has the same problem as me… just solder bridge it, I guess? Mine seems to have ended up fine, maybe yours will too, is worth a shot.
Informative! Thanks!
I think if I lost the attiny I would try to solder it back, even with the eight legs I feel like it’d be easier than that stupid tiny resistor, gah I spent so much time on that! I need a hot air station haha.
And I didn’t realize you could source whole new stock drivers, that’s good to know. I’ve got some TA drivers on the way from Lexel for my H03, looking forward to that.
