The There Are No Stupid Questions Thread
I’ve read there often is some oil in compressed air which is not good for reflectors. I use this tool with good success:
https://www.amazon.de/Giottos-GTAA1900-Rocket-air-Blower-schwarz/dp/B00017LSPI
One possible reason: lower voltage (all LEDs parallel) means higher current for same output which results in more resistance losses in cables, contacts, PCB traces et al.
Thanks Flashy Mike, just ordered one from BG, will try out soon!
okay, then Why CFT-90 not running on 12V led :stuck_out_tongue:
I havn’t found oil in the can of compressed air, but definitely use a dual air drying system on my air compressors when shooting lacquer
I’m going on a long bicycle tour and would like to take 2 18650 lights (Lumintop Prince and Nitecore HC30).
Is there a small portable charging device that I could use on my trip that I could charge and carry with me to charge up my batteries along the way?
Yes, there are several options for that. But there is one portable device clearly the most efficient, cheap and compact, it is called ‘spare batteries’ :slight_smile:
Depending on how long the trip is, there comes a point where it becomes more efficient to bring a charger rather than a mountain of batteries. :-)
Thanks for all tips guys, managed to get it quite clean.
I have filed down the reflector even more and now the bottom is really thin, just as the gasket, i think this is all i can get out of it, very happy.
To clean it i have rinsed it using running tap water and blew it out using my new dust blower which recently arrived. After that i used 70% rubbing alcohol which i still had lying around (kids…) and used cotton wool which worked great.
Blew it out once again and it ended up really well!
XPL-HI V3-1A with BLF X6 driver
I have got the Xtar Ant MC1 Plus, which is really small and useful, i just use my phone’s charger
https://www.nkon.nl/charger/xtar-ant-mc1-plus-li-ion-mini-battery-charger.html
Maybe this?
magchgr by F/8, on Flickr
solarchgr by F/8, on Flickr
I have a big 32650 waiting to be used on the flashlight. Anyone recommend me a light ? Thanks.
2D Maglite and a dummy cell?
There are no stupid questions...
but there are dummy answers.
My question is this:
Given that God is infinite, that the universe is also infinite and the speed of light is 299 792 458 m/s…
Would anyone like a toasted teacake?
Toasted teacake? Hmm… got any crumpets??
Ask me a question that is wholly unbready and not even slightly curranty.
I had a biophysics professor in college who was very fond of saying that any time infinity comes up in physics, it was natures way of telling you that you screwed up the math somewhere.
Does anyone have some good rule of thumbs on how many amps various LED’s typically pull in 1x18650 and 1x14500 lights?
Basically debating when to use higher amperage batteries (VTC6/30Q , Windyfire 14500) vs. higher capacity (NCR18650GA, panasonic 14500)
xp-g2
xm-l
xp-l
xp-l hi
xhp 35 hi
xhp 50
etc…
why li-ion cell is 3.7V, but not 3v or any other voltage?
