Good news I just got a chance to take apart a Shiningbeam P-Rocket and it had one of these new drivers and I was able to reflash it with the standard setup I have been using on the old Nanjg drivers.
Are you sure it's the same board? It seems to have a quite different pin layout; others said so, too.
Or did you refer to the PIC version of the NANJG105(A)?
Can you take a photo of the driver?
Welcome! IMO you’d be better off with the 1.5A version of this driver if using a 16340, especially if you are using a non-IMR cell. (IMRs are more suited for high current than regular (LiCo) cells). I tend to be on the conservative side, so others may disagree.
Last night I put a 2280 into my Yezl Z1x (UF2100) and boy does that get warm quick. I don't know how you guys with DD drivers in those things handle it.
Thanks mitro! Aside the heat, are there any serious cons with my configuration? Guess battery time will suffer, but if I use aw imr battery and doesnt run it on hi mode all the time it shouldnt explode, or burn the led or something like that…? I think it could be a pretty powerful torch!
Thanks for pointing this out Garry. It is definitely interesting. While I really appreciate JohnnyMac's work, this solution involves too much heavy modding for me.
**Solarforce, are you reading this?!** There is a massive gap in the market for a 3xAA P60 host with the same configuration as the Saik SA-305, using a 3xAA cradle. **Solarforce, are you reading this?!**
I'm not much of a fan of it, but the Dereelight Javelin with the extender seems like the better option for me.
While also being useful to me; this driver is screaming out to be gifted out in a 3xAA host to friends/family (non-flashalcoholics).
I did realize that after I posted. This one is just two little solder pads that have to be bridged. I had a heck of a time doing it but it should have been really easy.
I really like this driver and have used a bunch of them, the only problem I have is that the tiny spring will give fits in some applications. Sometimes I have to stretch the spring to make contact. The last setup I had trouble with was a SF L2T. I tried all of my longest batteries and it was still too short. The spring is very stiff so I dont just pull it to stretch it. I bend each coil up one at a time.
