Wow, I should check out this sub-forum more often, this flashlight looks amazing at $16...too bad I missed it.
Ive wanted one in that shape for a looooooooooooong time where the head part is at a right angle. I wish more flashlights were like this because its kind of rare.
Dam, i missed this :(. Ordered A KD c8, a DRY and as finishing touch a great headlight as this would have finished it all off :). Gonna check this subforum more often!
I wouldnt mind on buying one either, so Im waiting :D!
If you can get it for under US$40 delivered (including all taxes/fees) it is very well worth the money. If you can't. Buy a Zebralght H50/51 (r whatever the numbers are up to these days)
The numbers from my light tests are always to be found here.
Thanks but for 30$ Id rather get Fenix HL21, not quite the same versatility form-factor wise as H2, but still from reputable brand and much better looking spec-wise IMO for that price+has warranty.
If it goes on sale for 16$ then I might consider, tho some comments regarding switch issues and PWM made me wonder+short battery life on HI with NiMh (~1.5h?!) is not that steller either!
Got two without the boxes. No problem, less garbage.
I think the most has been said before and they work perfectly.
Thanks a lot for the deal!
http://www.nzrimfire.com/viewtopic.php?f=14&t=1911
did try to set one up here on our kiwi forum, but did not get much support.
Not sure if the coupon still works or not
II'z
Doesn't work anymore.
I like: walks on the beach, sushi and things that are paisley.
Hi
They should do a group buy again for this baby. Im sure will be a real success (again).
I know I want some ...
Anybody?
I would get one.
UFH3 is better
Gurus in Electronics: any idea where I could get a new micro-switch for my firends UF-H2?
His boy ate the rubber cap and smashed an apple with the light : light is constantly on / ramping :bigsmile:
Rubber caps needed also, thanks!!
i missed it..
i've ordered a UF headband instead..
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
By around 7 months
i heard that the parasitic drain is quite substantial (e.g. after 4 weeks)
Yep, if you forget to lock it out... threads are anodized. 1 or 2 turns at the tailcap stops parasitic drain.
Any more good group buys going on, or planned for soon?
I was going to say yes, but having read the caution above by the person who wrote
> PWM ... definitely not for use as a headlight for when I'm working in the workshop....
> ... not fun at all with a strobing light.
I'd've skipped it.
Not to mention it's an old long-dead topic that got revived somehow.
