Thanks for doing this test. Very impressed with output and low Vf compared to 219C.
Please keep us posted on how you end up using these LED’s in your future mods.
Low Vf in not a good sign when Vf almost stops rising with current, that is sign of overheating (Vf drops by ~2mV/C). Over 5~6A Vf rises too slow compared to lower currents.
Overheated or not, any LED in parallel will usually have lower voltage than individual. The internal resistance divided. I was talking about the already low Vf became so much lower when configured in 4p.
The low Vf is consistent from low current to max compared to a single 219C (it should be around 12A with the D320 R70). I know what you meant when the die overheats the voltage will drops. Judging by the voltage vs. output curve it’s not “yet” overheated for BLF standard. It is indeed much hotter than the R70.
Below is 6V configured, same board but with 4x D320 R70 E21A. The max current for 6V is approximately half the 3V configured. Texas_Ace stopped the test I believe because of his PSU could not feed it no more. In below 6V setup, it was peaked at 6A or 12A if we were to test it in 3V config.
FYI the phosphor temp will always hotter than the die (Only for E21A case). The difference can be as high as 30C in peak current.
My max current recommendation for this 3V quadtrix is 9,6A. As I said somewhere in the E21A thread. But you know, people like Texas_Ace and DBcustom will always enjoying the LED’s near death bright light experience. :cry:
- Normal heavily sinked and cooled the output peaked at 3,1A with very marginal output rise from 2,9A to 3,1A (it’s not really worth it)
- From 3,1A and above the output dropped sharply.
- At 3,4A all the silicone in the phosphor layer started to burn
Phosphor layer scraped, watercooled, the blue light kept increasing until the whole die completely burnt at ~7A (this is single E21A)
This evidence is a sure thing that the die would not overheats at the output peak current, only the phosphor layer. The phosphors itself can withstands ~200C but the silicone binder doesn’t.
We didn’t post the R9080 measurements due to inconsistency in measurement. But it was indeed hotter than the R70. I think Jensen567 still keeps the data.
E21A has special construction unlike ceramic based CSP LED (XD16 for example). Large portion of the phosphor layer are is isolated from the base due to the use of reflective barrier. It’s the white silicone-composite-something stuff surrounding the die.
The above measurement taken by Nichia was using normal MCPCB with very high thermal resistance unlike what we use in our boards (I believe we use the same technology ). With VR16SP4 board we can push the E21A far beyond it’s rated wattage. This also means the temperature difference also lower. Me and Jensen567 did many tests and found that the limiting factor is the phosphor layer not the die. We also found the phosphor layer max temp at max output always somewhere near the 180C surface temp.
Are there any drivers that could take a quad E21A to 10 amps? Over on reddit it was pointed out that with the Vf so low it seems FET would be a bad idea.
I’m imagining a high amp quad E21A build. Like a high cri BLF A6 competitor. Or maybe even a quad quad E21A build (four clusters of four) with a regulated driver that could push 15-20 amps. Maybe in a body similar to the S41.
It looks like I might of made a mistake with the single E21A tint. I thought it was 4500k but it might of been something else. I just looked at it again and the die is cooler then the others, so it very well could be a cooler tint. I don’t remember what Clemence sent me besides the mixed tint version.
djozz posted this photo of an E21A 2000k in a Copper Klarus Mi1c, it does not have an aspheric lens, that model uses a reflector with flat lens.
I will post photos of my Aspheric lens Utorch S1 Mini with 2000k E21A, in a few weeks, when it arrives from being modded by Clemence.
fwiw, the Utorch is on sale at gearbest for just $20 atm and the aspheric Mi1c is on sale for $30 (ask fin17)
trivia, the Klarus will memorize moonlight, the Utorch will not. fwiw, the moon mode on the Utorch is much lower, which I prefer. Only the Utorch offers a NW option.
Yeah, I think E21 quad is the best LED on the market for Mi1C (as it turns out - the variant with a reflector too) or Utorch S1 Mini.
At least when ignoring the price….
Correct, it’s very expensive. First is the board itself. Hopefully the manufacturer will reduce the prototyping cost for my next 20mm boards.
Second is the LED itself. At its early mass production time, the base price I got from Nichia was ALMOST the same as 219C R9050. Nobody would not believe me this because most people will judge from the physical appearance and the bulk material as seen. I have to lower the price just to make it looks “fair” to the customer.
Now its getting cheaper as more manufacturers are using them in their “creative” products.
