I disagree with this emitter being inefficient.
Now I don’t have hard numbers, just your charts, so my conclusions are fragmentary, but they don’t show inefficiency.
If you want to light-up an emitter surface to high level, it will become inefficient. That’s true for any emitter.
What is special about Q8WP one is that it enables you to overdrive it much further than others. This makes it’s more modest modes look inefficient….
Overdrive XHP35 HI E2 to 170 cd/mm². It delivers ~60 lm/W. Overdrive Q8WP to the same luminosity - you get ~80 lm/W.
Saying the same differently: drive it with reasonable W/mm² and it delivers reasonable lm/W. This is a small emitter and won’t deliver high lumens efficiently. But it doesn’t mean it’s inefficient - it means it’s small.
It would make a fine LED for multi-emitter throwers.
The XP-G2 S4 2B de-domed has a luminance of 142.9cd/mm^2 at 2.8A and has a 2mm^2 die.
The Osram Q8WP has a luminance of 121.8cd/mm^2 at 2.8A and has a 1.91mm^2 die.
So the Q8WP is smaller, but still has a lower luminance at the same (medium high) current.
If you compare them at 6A, the Q8WP starts to edge ahead slightly (205.9 vs 200.1) because of it’s much lower Vf (3.51V vs 4.35V !) coupled with the much lower thermal resistance. The difference should be much bigger. We need betters bins.
Why are you taking current in efficiency calculations? I think that power is more interesting. And thanks to lower Vf, at the same input current, Q8WP uses (much) less power.
Because it’s more relevant for many lights where you can’t or don’t want to switch out the driver.
The real efficiency is of course much better compared to older LEDs.
Big disadvantage of XP-G2 is that it's not factory undomed (tint issues after dedoming) and because of very high Vf (and often with large Vf variation between LEDs) light output starts to decrease almost immediately with single cells lights; this led can be driven with CC for a long time before output starts to fade.
I see your point. However this is not efficiency of the LED but rather the LED-driver combo.
Very low Vf makes linear drivers inefficient. But at the same time it enables use of very efficient buck drivers w/out falling out of regulation, leading to better overall flashlight efficiency than that of a high-Vf LED + linear.
Sadly, at higher cost. And even with 2 mm² LED currents get high enough to cause driver availability problems.
Yes, we need compact high-current buck & buck-boost drivers for 3V LEDs. Although it doesn’t really make much of a difference at high currents. At medium currents they start to make a lot of sense. The LD4 linear driver is a very good, cheap option at high-currents. It’s also rather compact.
Where someone sees disadvantages someone else sees advantage…
XP-G2 is still no 1 emitter in my single cell thrower builds (easy re flowing, easy de doming, easy centering, constant and very high lux performance, very reliable, imho the best and unbeatable led for single cell fet thrower lights).
Imho there is no big performance drop at all… Well it does happen because of DD or turbo mode of Fet driver with sagging 4.3-4,6A of current but that is nothing drastic comparing to XM or XP emitters in same configuration.
I absolutely love this driver. I mean the hardware features-size-price. But software doesn’t support e-switch. And is not open source, so I can’t customize it to my preferences.
According to Entwickler im Interview: Osram OSTAR Stage | Production Partner the glass lens on top of Ostar Stage LEDs exists only to protect bond wires. There’s air between it and the actual LED.
I assume Q8WP is the same. If that’s so, removal of glass will make it brighter than the Blackie.
For Q8WP I can confirm, you can remove the glass cover without damaging the bonding wires.
It happened to me accidentally as I used a center ring which not fitted properly to the LED. However the gain in flux is absolutely negligable and also the tint hasn't changed.
@Agro: I would not recommend this since such center rings are used to 'hold' the reflector at the desired place at the LED and have to withstand high forces of it. I would doing so only if the reflector is screwed in but in this case there is no need either.
I spotted a minor weirdness in the datasheet.
The peak output is not at cool temps. It’s not at 25°C. It’s higher.
Furthermore, the loss from heating up to 85°C is just 3%.
I’m not sure if we should believe this…if yes, we can expect it to have real-life performance quite close to this test.
