If, indeed, an owner can configure the Q8 to do what I suggested on the previous page in response to someone asking what I would consider the available functions should be, then the Q8 would be fine. Eventually I will follow up on that.
I have not gotten into much depth. Nor do I particularly want to. Back at the origins of the project there was significant discussion about using the Q8 with a light dispersing cover as emergency room illumination. That was where I got into this. There was a very promising project to do just that, but it went away. So I moved to the Q8. I wanted a light source for power outages or other general conditions (fire, quake, landslide, tornado, meteor strike, North Korea, etc.). There have been multiple occasions here of power lines down on the road or significant tree parts. No way a user responding to these problems will be trained or remember said training. And it is essentially impossible to presume who will need to use the flashlight under those sorts of problems. IT IS A FLASHLIGHT. My misunderstanding is my fault.
Responses keep being made about essentially âwell just train the usersâ. No. Not useful. Any random person can be a user. None of them will be âtrainedâ and or remember said training.
My wife will never get it. She has serious problems using the remote TV controller (including pressing all the damned buttons hoping something will change). I have not reliably gotten the Q8 right. This is an emergency light as far as I am concerned. I suspect there are others with this view. So we need a light once a year (or five years). No way we will remember the âinstructionsâ. I will maintain the battery charge regularly. If it is an emergency, nobody is going to read the instructions first. Many posts are presented that âeveryone I have given it to have used it with no problemsâ. OK. Good. You have some clever friends, or more simple friends that do not explore a bit. Four out of four people I have given a Q8 to try (including me) have failed the âclear and simple interfaceâ test and gotten to modes you absolutely donât want people to be using outside of very specific circumstances (e.g., blinding the bad guy [without blinding the good guy]). Really bad for moving vehicles, low flying aircraft, curious people looking at the light, interfering with police activity, etc. This thing is not a toy!
It is a natural response to an untrained human using a flashlight (or lots of other things) to keep pushing the button when something is not working like they expect. If it is not doing what I want; press the button some more. Personal observation of many lights, not just the Q8, but from really simple $5 lights on up; push the button some more.
The Q8 was designed by a flashlight hobby forum, believing that it would turn to be a 100% tool is naive, of course it is full of toy-features
But I also think that, with the limitation that it is not idiot-proof, it does quite well as a tool too, and perhaps even more so than comparable flashlights of expensive brands.
As I noted, I thought I was moving from one light to another with similar goals. My error. The complexity grew over time. I went with it. I know it is a flashlight hobby forum. I really do. I have been a member for about 4.5 years.
There are no obvious reasons why this should be hard. And alternate version of the software would be fine. A version of the software that allows an owner to select dumb or cool. With sufficient protection so that dumb and hobby shall never see each other. Some participants have offered solutions to change the Q8 behavior to something closer to dumb. And that will be fine. The choice of simple and hard would be very useful. But one or the other could also work at a reduced level. I am not currently able to go through the various alternatives. I have other issues to deal with.
Offering an alternate âdummed downâ version (or a switch) would be useful. And I think they exist. The manufacturer may also find an advantage with providing two versions. Dumb user and full blown hobbyist.
It is getting sort of old to be chastised for not understanding, and why did I participate. I did, and I did.
A flashlight of this power should never be able to go to a dangerous mode with a person simply wanting a flashlight. It does not currently meet that criteria. It is a disservice to people (random civilians) that just buy a Q8 and do not really understand what they are getting into. This light is dangerous in unskilled hands. And maybe some skilled hands, but that is a different discussion.
@ alternetyâŠâŠâŠ For the life of me I cannot understand what you find so difficult with this UI as it comes from the factory.
All you have to do is push the button & hold it till it is as bright as you want it & then quit holding the button down.
ThenâŠ. when you want to turn it off, click the button & it is off.
To me⊠this is not complicated at all. How much simplier could it possibly be?? Seriously??
Just how could that even be ââdumbed downââ??
And as far as it being a âdisservice to people (random civilians)â and âdangerous in unskilled handsââŠâŠ that may be your opinion, which is just fine. But I doubt it is shared by very many people. (which is my opinion)
And anyone should have enough sense not to look into the âbusiness endâ of a flashlight when they are turning it on and/or using it. IF they do not, they have no business using any flashlight.
I guess different strokes for different folksâŠâŠ. but, as I said above; I fail to see how this could be made much simplier than how it came from the factory.
When you want it ONâŠ. push switch button & holdâŠ. releasing button when desired brightness level is reached.
When you want to turn it OFFâŠ. click the switch button. It is then OFF.
Alternaty a solution to your problem is to buy another flashlight that meets your needs. Put the q8 in a cabinet somewhere else so you can have it as a reminder to research a product to see if it meets your personal needs and requirements before you buy it. By the way, a flashlight hobbiest website who teams up with manufacturers to make advanced flashlights that the members of said website can purchase cheaply is probably not the place to buy an emergency flashlight that any child can use. Good luck finding the light that actually meets your needs, maybe try the sporting goods section of your local Walmart. Cheers!
Iâve had good success handing the Q8 over to noobies. They figure it out quickly, itâs a fantastic product. For easy access I still have my old Malkoff converted 2 D cell maglite, on/off - easy/peasy. It never seems to get used though. My daughter likes to go walkabout with the dog late at night. I have a 1000 lumin Nitecore MH20GT now which I leave out for her that has a mini-USB plug so she can charge it whenever it needs. She had once grabbed my Convoy C6 to shine on the guy she caught breaking into my truck at 3am. We both learned that in an emergency, having a tail on-off switch AND a side button for modes was not a good idea. She was unable to work the flashlight, but the good news was the guy wasnât alerted and her phone call to the police resulted in his arrest.
I think Alternatyâs main âbeefâ with the Q8 is that while itâs âintuitiveâ to a certain point thereafter it rapidly can become nonintuitive. Itâs an understandable complaint considering that the average public user of modern led flashlights have generally been pre-conditioned by the standard fare of on-off-high-click-medium-click-low-click-possible-strobe click.
The Q8 ainât one of those lights to say the least. You really only get âintuitiveâ with it after you read the directions thoroughly and then practice with it a lot. It takes effort. It is NOT intuitively simple to use once you get much beyond the ramping up and down then just turn it off features. Again, I think thatâs his point and heâs taking a bit of umbrage at those that make him perhaps feel a bit stupid. All these videos explaining how to better clearly interpret the fine print directions is a testament to that deal.
That said, his point to consider from a potential increased sales standpoint that an intuitive version and a nonintuitive version being offered is a valid one. To sum it all up: KISS vs letâs make it challenging. Whoâs kidding who? The Q8 is ultimately challenging.
Clearly one may not know what theyâre getting into until one actually gets into it. Complex things tend to do that. The Q8 is NOT necessarily simple to understand unless you know what the creators of it intended it to be.
A typical led flashlight was obviously never the original intent here. This is an upper grad-level light, man. Iâm not saying anything profound here that hasnât already been said. Iâm just kinda defending the guyâs perspective.
Yup, the hard part of the Q8 is in not making it overly complicated on purpose.
Oh one other thing. If I had designed the Q8 UI in hindsight I probably wouldâve had TWO factory default optional settings.
One default is the one ya got now.
The second default wouldâve been the KISS option: Click-On get low, click again get Medium, click again get High, click 3 times anywhere in the cycle get Strobe click 4 times get moon. Or something to that effect.
If we had designed the Q8 as a light for dummies, I would change 2 things:
1)it would have internal charging, probably via a base, like your average electric kettle or tooth brush
2)it would have a turnable switch like the power/volume knob on old radioâs, turn it to switch on, turn further to ramp up.
Still a nice variant to consider having built, but complicated to design.
That. I keep thinking about new builds, but then I realize they wonât have an e-switch and Narsil/AndĂșril, and I lose interest. I need to find a good e-switch host, find a driver that will work with the cool firmware (and fit in said host), and start flashing drivers. Then I can mod or build again.
The first three people I gave the Q8 to play with ended pretty fast in configuration.
Since I have a standard introduction to the Q8, there were no more problems in handling the lamp.
I think it is not intuitive, more easy to get. But you can end up pretty fast in config/blinking if you only play arround.
Quick introduction for newbies or relatives:
- Donât hold the button down for longer than 8 seconds! The lamp will enter configuration and starts wild blinking. Donât push a button or you change things. In case handle it to a pro or search for reset in the cheat sheet.
- Donât look in the working end!
- One click on, one click off.
Push the button and keep it holding for ramping. Rember to release within 8 seconds.
