OK, I will be quiet!
Alternaty a solution to your problem is to buy another flashlight that meets your needs. Put the q8 in a cabinet somewhere else so you can have it as a reminder to research a product to see if it meets your personal needs and requirements before you buy it. By the way, a flashlight hobbiest website who teams up with manufacturers to make advanced flashlights that the members of said website can purchase cheaply is probably not the place to buy an emergency flashlight that any child can use. Good luck finding the light that actually meets your needs, maybe try the sporting goods section of your local Walmart. Cheers!
Iâve had good success handing the Q8 over to noobies. They figure it out quickly, itâs a fantastic product. For easy access I still have my old Malkoff converted 2 D cell maglite, on/off - easy/peasy. It never seems to get used though. My daughter likes to go walkabout with the dog late at night. I have a 1000 lumin Nitecore MH20GT now which I leave out for her that has a mini-USB plug so she can charge it whenever it needs. She had once grabbed my Convoy C6 to shine on the guy she caught breaking into my truck at 3am. We both learned that in an emergency, having a tail on-off switch AND a side button for modes was not a good idea. She was unable to work the flashlight, but the good news was the guy wasnât alerted and her phone call to the police resulted in his arrest.
I think Alternatyâs main âbeefâ with the Q8 is that while itâs âintuitiveâ to a certain point thereafter it rapidly can become nonintuitive. Itâs an understandable complaint considering that the average public user of modern led flashlights have generally been pre-conditioned by the standard fare of on-off-high-click-medium-click-low-click-possible-strobe click.
The Q8 ainât one of those lights to say the least. You really only get âintuitiveâ with it after you read the directions thoroughly and then practice with it a lot. It takes effort. It is NOT intuitively simple to use once you get much beyond the ramping up and down then just turn it off features. Again, I think thatâs his point and heâs taking a bit of umbrage at those that make him perhaps feel a bit stupid. All these videos explaining how to better clearly interpret the fine print directions is a testament to that deal.
That said, his point to consider from a potential increased sales standpoint that an intuitive version and a nonintuitive version being offered is a valid one. To sum it all up: KISS vs letâs make it challenging. Whoâs kidding who? The Q8 is ultimately challenging.
Clearly one may not know what theyâre getting into until one actually gets into it. Complex things tend to do that. The Q8 is NOT necessarily simple to understand unless you know what the creators of it intended it to be.
A typical led flashlight was obviously never the original intent here. This is an upper grad-level light, man. Iâm not saying anything profound here that hasnât already been said. Iâm just kinda defending the guyâs perspective.
@ nottawhackjobâŠâŠ. Well said and true. But as Throw me in to darkness said aboveâŠ. âit is only complicated if you make it soâ.
Forget all the bells & whistles completelyâŠâŠ stick with the basic on & off and it is very simple.
Past that, I agree completely; it is definitely complicated to the newbie as well as some who are not a newbie.
Teacher,
Yup, the hard part of the Q8 is in not making it overly complicated on purpose.
Oh one other thing. If I had designed the Q8 UI in hindsight I probably wouldâve had TWO factory default optional settings.
One default is the one ya got now.
The second default wouldâve been the KISS option: Click-On get low, click again get Medium, click again get High, click 3 times anywhere in the cycle get Strobe click 4 times get moon. Or something to that effect.
That would be one extra helluva light IMO.
Nottawhackjob,
Interesting thought. :+1:
Only problem there would be for some to figure out how to switch between each default. Unless it was light specefic that is.
If we had designed the Q8 as a light for dummies, I would change 2 things:
1)it would have internal charging, probably via a base, like your average electric kettle or tooth brush
2)it would have a turnable switch like the power/volume knob on old radioâs, turn it to switch on, turn further to ramp up.
Still a nice variant to consider having built, but complicated to design.
I will say this:
I would like all my flashlights to be so âcomplicatedâ
For me it is the best and very intuitive system.
That. I keep thinking about new builds, but then I realize they wonât have an e-switch and Narsil/AndĂșril, and I lose interest. I need to find a good e-switch host, find a driver that will work with the cool firmware (and fit in said host), and start flashing drivers. Then I can mod or build again.
Komeko,
If ya think the Q8 is very intuitive I bet you play a mean game of 3D chess too.
I do not have time to play and Iâm too old for it
The first three people I gave the Q8 to play with ended pretty fast in configuration.
Since I have a standard introduction to the Q8, there were no more problems in handling the lamp.
I think it is not intuitive, more easy to get. But you can end up pretty fast in config/blinking if you only play arround.
Quick introduction for newbies or relatives:
- Donât hold the button down for longer than 8 seconds! The lamp will enter configuration and starts wild blinking. Donât push a button or you change things. In case handle it to a pro or search for reset in the cheat sheet.
- Donât look in the working end!
- One click on, one click off.
- Push the button and keep it holding for ramping. Rember to release within 8 seconds.
You never should have bought this light. It sounds like you would be better served with a 4xAA light, of which there are several nice ones. Youâll only get 1000 lumens from them, but that is more than enough for almost every purpose.
I suggest removing the batteries from your Q8 and never use it again. It can be very dangerous if not properly handled, including doing things such as installing batteries the wrong way around, or accidentally turning it on high when itâs close to something flammable.
The Q8 is meant for flashaholics, and people with prior experience with 18650 lights. A ârandom civilianâ should not use this light. Itâs safe if used with common sense, but that is often shown to be lacking.
Since Banggood sells this light to everybody it actually should have a safe mode for ârandom civiliansâ.
With a pass code protected configuration menu this could easily be achieved.
This is a very nice AA Light. It takes 4 x AA. I use Eneloops in mine & love it!!
Okay, I have one answer to your comment:
Do you think that has a âsafe mode for random civiliansâ?
That would be a definite noâŠâŠâŠ
Hey WalkIntoTheLight,
Câmon, a cattle prod? A cattle prod is just like your typical flashlight within reasonable public consumer expectations of what a typical flashlight does? Most flashlights typically donât shock the living sh*t out of you even if you âmishandleâ one, right? Or can kill you if you have a pace maker, right?
Would you leave a cattle prod just laying about your home around people that donât realize what it can do? Do you really think a live cattle prod and a live Q8 on a kitchen table unsupervised around kids is a valid argument for debateable comparison here?
Whatever Banggood does or doesnât do when they sell cattle prods is one thing. Reasonably expecting Banggood warning the public about flashlights to the extent that a cattle prod warrants is another thing. I donât know but maybe thereâs no legal requirement to warn about anything that Banggood sells within Chinaâs consumer protection laws for items of this nature. Basically what Iâm saying is that if you buy a cattle prod Banggood has a reasonable expectation that you already really know what youâre dealing with there.
Now if youâre talking about a new just hit the general consumer market high power laser that goes for only $5, will burn a hole through drywall, and looks like a flashlight, yeah Iâd think Banggood would have some extra responsibility to make an extra effort to warn their unsuspecting customers random or not of this new productâs untypical hazards. I would hope so.
The point from previous comments that from Banggoodâs perspective a Q8 should warrant a big deal warning OTOH doesnât fly either so your point is well taken but the comparison to a cattle prod here is where I lose the argumentâs valid connection.
Iâd really like to see drivers designed to use the little DIP switches.
4 or 8 switches on a small board gives the option of a whole lot (2 to the power _) of settings.
