I’m really happy with my mc3000.
I didn’t program the charger itself, but have set al different charge and discharge settings i have on my phone.
So yust put in the battery, select what i want to do on my phone and of it goes.
I’ve had the Opus v2.2 for a few years, and has always served me well, and the fan never bothered me. However, I was always looking for a way to discharge or “store” batteries. I have close to (60) 18650, 350’s, 340’s, 26650’s & 14500’s. Was going to buy the MC3000 because of this function. Then decided to just use 2 Miboxer C4-12’s, and dedicate the Opus to discharge cells for storage. Set the switch on the bottom of the Opus to 3.7v. Discharge the cells, then charge. They stop at 3.67v which is perfect for long term storage.
I do it all the time no problem. In dummy mode the MC3000 is just as easy as the Opus which I also own but have no reason to use any more. If you are satisfied with the preloaded charging amps value then its a one button start. The Opus is beaten by the MC in every single aspect but the price. I can afford $85 so quality and features won over value and I’m very satisfied.
I am about to buy a second MC3000, as this is the first charger I encountered, which can be set to NOT cook my NiMH batteries (I use them in many of my devices, but a considerable majority are with li ion batteries).
I’ve got several chargers now: Xtar VC4, SkyRC MC3000, Opus BT-C3100 v2.2, Miboxer C4-12, Lii-500.
For place-and-forget, I think the Miboxer C4-12 wins for ease of use. (just place the battery in the charger, and it charges automatically based on the battery’s internal resistance (so VTC6 and 30Q will charge very fast, most of the time, when at least half-discharged, the Miboxer will auto-select a 3.0A charge current — not sure if this would be bad for battery cycle lfe for the VTC6/30Q though.)
But for other analyzing and precision tuning stuff, then the MC3000 is simply the best (can adjust charge current and discharge currents in 0.01A increments), can also specify at which voltage to stop charging, and I think this is the only charger which can be configured to stop charging when battery temperature reaches a user-specified temperature.
I’m not sure if any other chargers has temperature sensor, other than the MC3000 and the Miboxer C4-12 (I don’t see temperature sensor on the Opus BT-C3100 and certainly not on the Lii-500/Zanflare C4/XTar VC4).
For the Miboxer C4-12 — it shows battery temperature, but I’m not sure at which temperature it will pause charging (I’ve seen around 50 deg C battery temperature when charging VTC6/30Q at 3.0A charging current).
As I’m sort of a control freak, I like the fine tuning of the MC3000, even though basic charging does require a few more steps (ie. select the pre-programmed number), plus the graphs (that can output to PC) also tell me something about the batteries charging behavior (not that these are needed for casual charging; but useful when comparing different batteries performance). Some features of the MC3000 can be hidden or not easy to access, after owning the MC3000 for a few months now, I just recently discovered how to do an internal resistance check for all batteries (previously, I had to do a charge or discharge and scroll down to see the “Battery IR”) — by pressing the Up and Down arrow keys simultanenously, it shows the IR of all batteries (when the batteries are idle and not “charging/discharging” states), which is very handy (equivalent to the “Quick Test” of the Opus BT-C3100.)
I recently bought the MiBoxer C4-12 at Amazon. The UI is kept very simple as there is just one single button you can press. Unfortunately, my C4-12 indicated unreasonable IR values on all of my tested batteries (Enerciq TN14500HP with 180 mOhm, Keeppower 14500 840mAh with 280 mOhm, Samsung 30Q Button Top between 770 and 999 mOhm), causing the device to charge with less than 0.5A. Slot 4 of the C4-12 mistook my 30Qs @ 3.67V with NiMH instead of Li-Ion. I cleaned all contact surfaces but it did not improve anything. With a heavy heart, I sent it back to Amazon as I still believe that the C4-12 is a very good charger (when working correctly).
I will have a look onto the MC3000 (Model 2018 with 2 cooling fans) now as I am enthusiastic about all those features many other charges do not have. There were only some minor complaints about too loose retaining clips with the updated 2018 version. For the time being, my Enova Gyrfalcon All-44 will remain the “insert battery and forget” charger.
What is happening is that these chargers are not laboratory-grade devices that can accurately provide the IR to last milliohm, and in fact, their manuals give such disclaimer about it. Nevertheless these chargers can at best approximate the IR of any given battery, features that we neglect and even consider before the advent of these chargers.
The C4-12 has very sensitive IR feedback that its auto-mode may err on the safe side than the other way around, automatically selecting a leisurely rate of .3A and thereabouts.
Choosing its Manual mode is actually like what we are used to experience when we used the ‘old’ chargers that don’t have digital displays nor gives out IR readings but just keep on pumping 1A regardless of the cell’s IR, but we are just not aware of it then. That’s the reason why with these dumb chargers, high IR cells will just heat up rapidly and dangerously and yet continue to charge it…while the C4-12 will never allow that if it is in ‘Auto’ mode, in my experience, some cell’s IR when charged at a very low starting voltage (like my numerous brand-new Samsung INR-18650G that arrived to me at a very low .72v) of about 230 to 260 milliohms, started at .3A but when the voltages started to rise in the 2.5 to 3v range, the IR started to go down and the charging rate started to go up, some as high as 1.80A, though some of those cells of mine never recovered.
That’s my experience…have you ever used or charged using the C4-12, put in a .72v Samsung INR-18650G that stayed in that state for months? You can’t argue with my first-hand observation, regardless of what your high-end instruments tell you with your brand-new cells.
I did not say anything about your cells IR, just that many chargers would have used a low current, because they do that at low voltage. It has nothing to do with high or low IR.
Well, I am talking about MY cells, and the IR showed by the C4-12, and will select low current when in Auto mode but my Xtar VP2, (charging the same cell/s with high IR based on the c4-12’s) will nevertheless charge it will at 1A. How do I know it charged it at one amp? I took note of the time it reached full-charge.
It is indeed a good charger. Some kind of “insert battery and forget” device. I only have some trouble with button tops in this charger. The voltage indicated on the display often does not correspond with the actual voltage of the battery, e.g. if a button top cell is partially discharged to lets say 4.05V, the Gyrfalcon sometimes measures 4.20V and will not even start to charge. Disconnecting the battery for a couple of times in the slot finally solves it. Furthermore, the voltage indicated on the display will not be updated for quite some time even though the cell is still being charged. It looks like the display is kind of frozen to the initial value for at least 20-30 minutes before it is being updated. Of course, all areas of contact have been cleaned before I started to charge the cells.
I think we are pretty lucky right now to have a lot of good chargers, they will all have small issues and quirks though. I don’t think the average person, or flashlight enthusiast even, needs the MC3000, but if the UI was sensible and not scatter-brained I would recommend it more. If you want to use computer control then that is one way to tame the MC3000 and use its advanced features. I’m thinking now that the technical details are sorted with the hardware, maybe they will make an update which is basically a UI change, and maybe add a nice WiFi connection to it for reliable control from a Cellphone or tablet. On the other hand they have spent a lot to develop it already I’m sure, and might be ready to just call it a day and say “it is what it is”.
Recieved my MC3000 last week. Been charging/discharging/refreshing almost nonstop since then. :sunglasses:
I don’t really like the battery sliders, but I guess if you want to accomodate all battery sizes without any additional adapters it takes a toll on usability. Also the UI could need an overhaul. Not being able to name or group the charging programs makes it unnecessarily hard to choose the right program.
Super easy. There’s two ways: Select program on one bay and then choose to save it to “all slots” and done. But even faster you can copy your favorite programs to all slots with a combination of just two keys. (see here: MC3000 cheat sheet )
I happened to come upon this thread.
I had a Nitecore, I forget the one, with 4 slots which I gave to a friend.
I have been thining about getting back into RC and do not want to purchase both a charger for cylindrical cells and RC batteires…especially since I think I may get a DJI which has its own system.
Anyway, I built two different battery holders capable of holding quite a few cells of various sizes….one is in parallel for charging and the other is in series. The later one I am using to test how batteries lag with my laser drivers.
The former one, I simply put either one or groups of the same batteries in, set my CC CV PSU for 4.2 and set the proper charge current for the specific capacity….and wait. Usually, I charge when the voltage is high enough that it is in CV mode. I wait until the current drops to zero and voila….4.2 volts….Yes….if the batteires are not equal in terms of capacity at time of charging…not good. Since I started this….I have not had problems….
except that my new Samsung 30Qs seem to take quite awhile to charge at 1/2 to 1 C
The one thing that I do need is a simple way to discharge my batteries for storage and if possible, measure capacity. I was thinking of buying a SkyRC hobby charger….but I really don’t need it.
I have yet to find an inexpensive way to discharge and measure capacity…any ideas?
