Has anyone gotten an emitter current read yet? What, about 3.6A to the emitter? Would like to find out what the driver is pushing up top…
So 6V diode, which gives us 30W, hmm 10W loss on the controller. 75% efficiency
Thanks Komeko for the valuable info. I received my TC20 two weeks ago and the color temperature is slightly warmer than my zebralight sc5w II 4500k. It is much warmer than my 5000k flashlights and close to my 4000k flashlights, which I prefer. However, it is high above the BBL line so it has more green than my other flashlights. I’m curious where did you order yours from and when did you receive it? I don’t really know how to read your color chart but is yours above or below the BBL line? Is it more or the greenish or rosy side? If it’s below the BBL and more on the rosy side, I want to buy another one because it’s such a perfect practical flashlight and the only thing I currently don’t like about it is the B or C greenish tint they use instead of A or D rosy tint.
It will be 3C near the main line and near 3B. For me, there is no green, there is more yellow which gives the impression of a warmer color than it really is. BLF Q8 has a lower temperature and it seems cooler because it is not so much yellow.
I ordered on the company website and the shipping was from Amazon.
darn I was hoping they revised the light color. I like warmer color temp but I don’t like yellow.
This is probably the general charm of XHP70.2
The Acebeam EC50 III has practically the same lighting characteristics.
The center is white, the crown is yellow.
The XHP70.2 4000k and 5000k MT09R and Acebeam H15 5000k XHP70.2 and none of them had as much greenish yellow as the TC20. The 4000k 80CRI on the MT09R had much better tint. But don’t get me wrong, the TC20 tint is not ugly. I’ve seen much worst. It’s just not as ideal as I hoped for. I still really like the light because it can maintain the high lumens so much better than other lights making it my most practical portable light.
I’m size sensitive - the larger a light the less likely I am to use it. But of course I like large output, and decent runtime. D4 size is great, but runtimes seem absurd, just can’t justify buying it for such a short wow time. I’m guessing that until there’s another large leap in LED efficiency the TC20 is the current king of output/size with high output runtime that’s longer than a joke…
With today’s offerings it can be difficult to choose the right light for balance, we now have choices that skew the parameters far and wide so coming back to a happy medium get’s complicated.
The problem is that for most people only lumens are important. Manufacturers wanting to “meet the requirements” of these customers, install P2 diodes because they are the most efficient. Of course, the color suffers. There are XHP70.2 diodes which have 5000K and CRI 80 and 90. They are N2, M4 and M2 models, but for comparison their performance:
P2 CRI70 1830 lm for 85 degrees
N2 CRI80 1590 lm for 85 degrees
M4 CRI90 1480 lm for 85 degrees
M2 CRI90 1380 lm for 85 degrees
Knowing me, as soon as I get N2 I will make a change
I look for M4, but hardly available to buy.
Mike
Only probably not available from stock. In addition, I see 12V and in TC20 is from what I know 6V
That’s why I wrote “hardly available to buy”
I have a problem with turbo. All cleaned, it drops from circa 8A to 6A in 1 sec.
Any clues?
Mike
12V is merely a matter of which board it’s on and how that board is set up. The XHP-70.2 can be set up to run in 6V or 12V, it’s the same emitter either way.
The chaufer in the study.
Oh, sorry, what multimeter or clamp meter are you using to get that 8A reading? If a clamp meter, what gauge wire for your loop? What cell, and is it fully charged to 4.20V?
Great news, I will be hunting for a super hyper pure white LED
I like the Noctigon or MaxToch 6V MCPCB’s for their heavier trace in the 6V configuration. Since we like powering these emitters up, a heavier trace to carry that current just makes sense… SinkPAD also has a nice 6V version of the XHP-70/70.2 MCPCB. You should even be able to get similar directly from Simon at his Convoy store on Ali Express.
Cell fresh from charger. I use DMM with thick cables I used to measure different 8A+ lights. Only this TC20 show me this amperage drop.
Other cell is on slow boat from China, maybe I will try with 18650 30Q cell I have.
Mike
